Old 02-25-2010, 11:05 PM   #1
Brent
Brent's Avatar
Tie Rod Replacement
Hi Everyone,
Just finishing off my steering work and replacing the outer tie rods.
One of them screwed onto the steering knuckle tight, but for some reason I can't tighten the other one. It just seems to rotate the entire ball joint.
Does this mean that the rod is broken? Why did one tighten right up, and the other will not tighten up much past hand tightening?
Any help is appreciated (I bought pretty good quality, life time warranty, so it's not because of the equipment)...
Brent is offline   Reply With Quote
Old 02-25-2010, 11:10 PM   #2
e30_kid89
The Afro-stig
e30_kid89's Avatar
Put a jack under the ball joint, keep lifting till you just start to lift the entire car. (hear creaking noises)
You will be able to tighten the ball joint then.
Goodluck!
Old 02-25-2010, 11:19 PM   #3
aaron320i
Send a message via MSN to aaron320i
or use a channel locking plier and squeeze the joint while tightening.
aaron320i is offline   Reply With Quote
Old 02-26-2010, 12:00 AM   #4
Use the jack method. Much less chance of damaging something than with that plier solution.
Old 02-26-2010, 09:09 AM   #5
Brent
Brent's Avatar
Thanks guys, I will try that tonight, hopefully I can get it done before 9:30 lol
Old 02-26-2010, 11:48 AM   #6
supernaught
supernaught's Avatar
are you talking about the tie rod end threading onto the inner part? or the balljoint into the strut? If you're talking about the end(#8 below) onto the inner(to make a #4), you will not use a jack, but use visegrips or a pipewrench to hold the inner while you thread the end on far enough that you can drive to get an alignment. If you can't tighten the nut on the balljoint(#9), use a jack as described above.
Old 02-26-2010, 05:34 PM   #7
Brent
Brent's Avatar
Cool diagram, thanks. Yes, it is #9 that is causing the issue. I will try the jack method and post tonight.
Old 02-26-2010, 09:09 PM   #8
nonlocal
Last of the Late-Brakers
nonlocal's Avatar
The diagram is from http://www.realoem.com
If you're working on a BMW you should really get familiar with that site, it's like the bible but without all the lies
Old 02-26-2010, 11:46 PM   #9
davericher20
black and blue
davericher20's Avatar
Old 02-28-2010, 12:14 AM   #10
Brent
Brent's Avatar
Goodluck!
Great advice, it went on perfectly when I did this. Thanks!
Old 02-28-2010, 01:27 PM   #11
e30_kid89
The Afro-stig
e30_kid89's Avatar
Old 03-01-2010, 01:39 AM   #12
E30M42cab
Parts Hoarding Specialist
E30M42cab's Avatar
Brent, it's funny how you got the damn things off without using the jack... usually the nut spins the ball joint when you try to undo that same nut.
Grow up and move on.
Old 03-06-2010, 06:54 PM   #13
Brent
Brent's Avatar
It's been a while since I took them off, but if I remember right I think I may have just cut them off with my trusty $10 rotary tool from Canadian Tire...lol
