Old 02-22-2010, 04:58 PM   #1
davericher20
black and blue
davericher20's Avatar
M-Tech steering wheel
I recently bought an m tech I steering wheel....I have an airbag steering wheel and I want to swap it out.....
I did a quick search but couldn't find anything concrete, anything I should know? adapters? washers I need......will it interfere with the dash? Is it a straight swap?
Old 02-22-2010, 05:19 PM   #2
Ceeker
there is one spacer needed to take up the slack on the longer shaft. I don't know what the part number is but you'll definately need this. I think the wiper stalk needs to be shifted further down the steering column. part is still available from BMW.
1 90 325is white - keepin
1 87 325i vert -red - keepin
KEEPER 88 5sp Vert 2016
Old 02-22-2010, 06:39 PM   #3
E30M42cab
Parts Hoarding Specialist
E30M42cab's Avatar
^^Yeah, you'll need a bit of a spacer on the shaft (just use some washers). The turn signal stock will be rather close to the steering wheel, but it's almost better having it that close. The splines will be fine though. I did the same swap on my Dad's '92 E30 vert with an airbag.
Grow up and move on.
