02-21-2010, 05:01 PM
#1
E30 POWER
Car: e30 327I TURBO
what injecters to use for turbo
alrite guys i am now replaceing the injectores for my turbo set up,,,,so i went on ebay and typed 24 lbs injectors,,,and 3 kinds came up ,,,,,,there were the ford racing 24lbs(not bosch manufacter but will fit still),,,and there was ford 24lbs racing bosch design 2 and design 3,,,,,,
i guess what im asking is what one will work best wit my application(im running stock 173 ecu)????? and another question is whats the difference between them all,,,,and most of all whats the difference betwwen a design 2 injector and a design 3 injecter?????? will they work the same
thanks guys ur thoughts will be great
02-21-2010, 07:06 PM
#2
The Afro-stig
Car: Is Fast. ;)
I think the only difference is the spray pattern. The ford racing ones are good and have been used by others with no problems. Id go with 30lb injectors however since its about the most motronic can handle.
02-21-2010, 09:54 PM
#3
E30 POWER
Car: e30 327I TURBO
i thought of going twit the 30lbs ,,,but my only concern was will it start up ok and not be chugging to barly stay started,,,cause its receiving to much fuel,,,,,,
02-21-2010, 11:39 PM
#4
The Afro-stig
Car: Is Fast. ;)
Thats where the tuning comes in  good luck!
02-22-2010, 12:46 AM
#5
E30 POWER
Car: e30 327I TURBO
so what r my options on tuning this car ,,,i got a wideband from innovative ,,,,,and a chip copy of tcd,,,,the only way i now about tuning this car is messing around wit the rrfpr and the afm til i can receive the proper a/f ratio if i can even get it proper due to limited ways of working wit montronic,,,,,if there r other ways for me to so say getto tune this car please help me out cause i think on start up im going to need it
thanks
02-22-2010, 01:04 PM
#6
Car: 964C4, TDI Golf
A "copied" chip? Nice.
(please note sarcasm)
I'd suggest a megasquirt, frankly. It's THE best thing you can do for this kind've stuff. It's relatively cheap to implement, it's OpenSource (so you can copy to your hearts content  ), and it's really quite flexible. Tuning IS time consuming, but there are so many tunes out there, you'll probably find an existing one that is "very close".
1998 328i "M-tech"
2001 TDI Golf. 1300km/tank commuter. Boring, slow, cheap.
1991 P-car: 964c4 Let the porcupine jokes commence.
Gone: '99 M3 vert, '98 M3 sedan, '91 E30, '89 E30, '87 E30, '91 Euro M5, '93 6-speed Corvette, STI v8 swapped '98 Impreza, '73 2002, 2004 325iT
02-22-2010, 06:47 PM
#7
E30 POWER
Car: e30 327I TURBO
well i had a buddy just call me ,,,he has a 97 m3 that he turbocharged,,,but is now upgrading it to run more boost so he is getting rid of his old injecters which r 36 lbs,,,,,he was going to just give them to me,,,,will the computer be able to handle these injectoers,,,,,and do u guys think that its a good idea for me to try them,,,,would the work if i had a lower fuel pressure rate
02-22-2010, 10:29 PM
#8
The Afro-stig
Car: Is Fast. ;)
I'm not sure if it can handle 36lb. I *think* somebody was running 42lbs on the stock computer but later threw it out for MS.
As far as options go for tuning, you just listed em
02-27-2010, 10:53 AM
#9
Car: 74 tii, 93 M5x2, e90
thanks
You got a copy of the TCD chip I developed for TCD that he wanted to pay me peanuts for? That chip only has timing mods. You need a custom tuned chip to handle the fuel also.
Thread Tools |
Display Modes |
