Old 02-13-2010, 11:53 PM   #1
m50tech
m50tech's Avatar
Vanos question?
Just notice my m50 lossing power so I checked the fuel presure is good new plugs changed coils tps sensor o2 sensor and still the same my bro was telling me it could be my vanos you can here the gear noise but very little. So could it be that my vanos is causing me to loose power.
e30 v12 coming soon!!!!!!!!
m50tech is offline   Reply With Quote
Old 02-14-2010, 02:56 AM   #2
aaron320i
Send a message via MSN to aaron320i
not likely
aaron320i is offline   Reply With Quote
Old 02-14-2010, 04:05 AM   #3
doogee
Stance is Gay.
doogee's Avatar
Very likely. Best place to start is by ordering a new Vanos seal from BeisanSystems.
When my seal was shot, I had it replaced and felt a massive improvement.
My Vanos was jammed.
Dakar M3 Track Build Thread
doogee is online now   Reply With Quote
Old 02-14-2010, 08:20 AM   #4
nachos23
SweetXi
nachos23's Avatar
It MIGHT be a Vanos, but it doesn't sound like you ar experiencing any of the telltale signs of vanoe issues......
Typical symptoms:
What are the symptoms of a failing vanos?
Overall loss of torque and power, particularly in the lower RPM range, < 3k. Bogging then surging at 3k RPM. Uneven power distribution and RPM transition. Engine hesitations in the lower RPM range, < 3k. Louder idle and intermittent idle RPM hiccups. Difficult takeoffs. Loss of power and bogging when AC on. Increased fuel consumption.
Double vanos cars with the M52TU engine (98/99-00) experience cold weather cold start idle jolts and possible stall.
Usually worn Vanos will nake an aweful racket and are quite noisey. I'd start by looking for a vacuum or air leak in the intake or PCV system. Use combustion chamber cleaner (while running) and spray around ALL intake components and vacuum lines. Listen for canges in engine rpm. Make sure to check the PCV valve. The main house leading from the bottom is prone to failure (overheating makes it break down) and will cause your symptoms....
ONLY after you've confirmed none of these are the culprit, then start looking @ the vanos. Eliminate the obvious and then look for the less obvious.
My Ride:
2004 330Xi
DCT Electronic Shifter
Bilstein and H&R sports suspension, Rogue Enginerring Race Brace
AA Stage2 tuning
Conforti CF Cold Air Intake
Hamann Front Spoiler and Side Skirts
BMW OEM rear wing spoiler.
M3 SMG Paddle Steering Wheel and M3 Seats
18" M6 custom painted wheels
Custom red kevlar interior
Magnaflow Exhaust
VIS CF Hood
Old 02-14-2010, 08:22 AM   #5
doogee
Stance is Gay.
doogee's Avatar
Just wanted to add that my Vanos was jammed but did NOT make any noise.
Old 02-14-2010, 08:37 AM   #6
archins
Send a message via Skype™ to archins
engine control unit have some errors? If it's vanos it must tell some foult codes
BMWMPOWER.LATVIA
archins is offline   Reply With Quote
Old 02-15-2010, 11:25 PM   #7
m50tech
m50tech's Avatar
Thanks for the replys found out that my idle control valve was not working very good it would open but all the way and not close back up thanks for the help
Old 03-01-2010, 11:14 PM   #8
aaron320i
btw if you still hear the grinding noise it is most likely you timing chain rattling the valve cover. Change the hydraulic tensioner if it get too irritating.
