Old 02-12-2010, 01:23 PM   #1
allineman
1992 325i no compression
I have a 92 325i that just stalled on the interstate. Fluids are good, Cams are in correst position and gears are aligned. It was running fine but just quit... Why would I get 0 compression on all 6 cylinders out of nowhere?
allineman is offline   Reply With Quote
Old 02-12-2010, 02:11 PM   #2
Mad Cow
Sounds like all your valves are open or broken/bent, did you take off the valve cover to inspect? If it was a piston problem you would likely at least have a tiny bit of compression in at least 1 cylinder.
Mad Cow is offline   Reply With Quote
Old 02-12-2010, 05:04 PM   #3
ScotcH
Just stalled, eh? Is that the complete story? Either the timing chain broke, or you money shifted and bent all the valves.
