Old 02-08-2010, 01:52 PM   #1
Educate me on VW's. (1999-2002 passat/jetta)
My girlfriend needs a car. Anyone owned one of these? Problem areas? Model year changes?
She'll get an auto cause she's lazy.
TIA
Old 02-08-2010, 01:55 PM   #2
magnus
magnus's Avatar
What particullar model are you after?
If its the turbo there is a comon fault with the coolant system. Nothing major but quite fidly to fix as it leaks between the engine and firewall.
They seem to like eating links and track rod ends. Also i ve heared a common fault is the doors at the back dont open.
Make sure timing belts were and are changed just before the service as they are known to snap as soon as you get to that mark (e.g. 100.000km in the book means change at 95.000).
Other than that if you go for an NA model i havent heared any major issues apart from the VW stealer being way expensive!
http://pics.livejournal.com/blblblblx/pic/000r554e.gif
"Lo there do I see my father.
Lo there do I see my mother.
Lo there do I see my brothers and my sisters.
Lo there do I see the line of my people back to the beginning.
Lo they do call to me
they bid me take my place among them in the Halls of Valhalla,
where the brave may live forever"
magnus is offline   Reply With Quote
Old 02-08-2010, 01:57 PM   #3
I dont take anything to the dealer.
Probably a 1.8T. Got a link for the coolant problem?
If the 1.8T's are really bad i can look for something else, but most of the cars around here seem to be the 4cyls.
Old 02-08-2010, 02:06 PM   #4
magnus
magnus's Avatar
They are not bad. 1.8T is a great engine with allot of potential. Timing belts are crucial though and make sure the catalysor is ok as on high boost they melt them.
Upgrade parts though are easy (from other VW group cars say Audi S3).
i will try and find a link for the coolant problem but i know it from a friend who works for Audi and they have this happening all the time on older A4 1.8T
Old 02-08-2010, 02:08 PM   #5
magnus
magnus's Avatar
Here:
http://www.vwforum.com/forums/f15/1-...nt-leak-32884/
Old 02-08-2010, 02:10 PM   #6
magnus
magnus's Avatar
Here is an even better one:
http://uk-mkivs.net/forums/p/155942/1029860.aspx
Old 02-08-2010, 02:38 PM   #7
^^thanks, i'll keep an eye out for that problem.
The car wont be modded, just tints and wheels.
Old 02-08-2010, 04:28 PM   #8
NOTORIOUS VR
NOTORIOUS VR's Avatar
Get her an auto 2L Golf... as new as possible. That will = the least amount of problems.
Old 02-08-2010, 05:36 PM   #9
Dado 540
Dado 540's Avatar
Jettas = electrical problems
Pay attention to the Jettas on the road. Guaranteed that either driver or passenger side tail is out and maybe hadlight.
E39 540i Sport
Old 02-08-2010, 08:37 PM   #10
I can very easily fix that kind of small electrical stuff. What else?
Old 02-08-2010, 11:07 PM   #11
davericher20
black and blue
davericher20's Avatar
vw owners secretly want to drive bimmers.
Old 02-08-2010, 11:09 PM   #12
El Gato Liso
El Gato Liso's Avatar
we just got a 99 passet 1.8T the other day....
turbo had to be replaced....it was a mess how bout that.
cant even full throttle without it cutting out....
once the car is done being used, its GONE!
if she needs a car for temporary sake, its fine....otherwise dont do it!! (passat, i cannot speak for the jetta though...)
R.I.P. E30
Old 02-08-2010, 11:28 PM   #13
Did you inspect the car before you got it? I feel like that's something you could catch.
Old 02-08-2010, 11:56 PM   #14
NOTORIOUS VR
That's not an electrical problem... it's just the bulb tray that causes that... not a big deal at all.. Some bending here and there and it's all good.
Dude.... the car obviously has problems due to neglect. Just because you don't know anything about cars doesn't mean anything.
propr'one:
Honestly, the big issue about the Passat of these years mentioned is the same as my car (same platform -B5-)... Control arms and wheel bearings. Plan for these approx. every 100-120k km. Not that big of a deal especially if you don't lower the car or drive it hard which I'm sure his GF won't do.
The 1.8T is solid. Other then the early cars had problems with oil sludge due to owners not doing proper oil change intervals and not using synthetic. So if you're looking at an older 1.8T, try to get one with docs showing proper oil changes were done. Listen for clunks and squeeks in the suspension and humming for the wheel bearings. If you're looking @ an automatic, listen for clunks, hard shifting, or slippage. But for the most part the trannys are ok.
Old 02-09-2010, 12:33 AM   #15
^^thanks dude, advice appreciated.
