Old 02-12-2010, 10:06 PM   #16
RMPMOTORS
RMPMOTORS's Avatar
Originally Posted by nachos23 View Post
My front sway bar uses a 23.5mm diameter bar. I've seen poly @ 23mm and 24 mm, guess I'd go with 24...... shouldn't there be a 23.5mm bushing or is the 0.5mm spacing normal? You carry the correct ones I need?
I would get the 23mm one and make it fit, snug is better then loose...
www.RMPMOTORS.com
www.Facebook.com/RMPMotors
Old 02-12-2010, 10:13 PM   #17
nachos23
SweetXi
nachos23's Avatar
cool check!! Thanks! knew there had to be an esy check for it.... Other than the changes I've done (and yes coilovers or cup kit would have been better), any suggestions to grab that last little friction?? I know winter cold and winter tires are certainly NOT the best combination for traction (running Maragoni's; Pirelli P0 knock-offs which are excellent), but trying to further reduce understeer in corners and some additional stability @ high speeds....
My Rides:
2009 335Xi
520HP
H&R coilovers
BBS LM wheels
//M sport package
BMW Personal Audio System
2000 Z3M
Conforti tuned
AFE CAI
++More to come this winter
Tags
330xi, e46, pre-loading, suspension, swaybar
