Old 02-10-2010, 01:41 AM   #16
slemmer
Driving in the fast lane
slemmer's Avatar
I had a similar problem with my '00 e38 Sport. One Summer day I decided to give my ride a thorough cleaning. I pulled off the bottom moldings only to find bubbling along the bottom seams. I grinded off all the beads to see corrision along the bottom of the seams on 3 of the 4 doors. A couple of doors had to have the beads removed halfway up the doors!.
Took the car to Meadowvale Collision (part of the Atlantic group of companies) and had them do finishing prep, bead, paint. I pass by this palce everyday. Carstar and European wanted a lot of money for the work which I couldn't justify. Once I got the car back it gets Winter stored after an annual oil spray to keep corrosion at bay.
It's been four years since I had the repair done and so far so good. No more reappearance of the cancer.
'15 Ford F150 Lariat SCSB 4x4
'04 645cic
'00 740i Sport
Old 02-10-2010, 02:18 AM   #17
faiz
That sounds like what I'm looking for. Did you drive it in winter?
faiz is offline   Reply With Quote
Old 02-10-2010, 02:21 AM   #18
slemmer
slemmer's Avatar
Not since I had the repair done. I've got another ride that's made for the Winter. I don't even take it out if it's going to rain (at least avoid as much as possible). Call me overprotective.
'04 645cic
'00 740i Sport
Old 02-10-2010, 03:56 AM   #19
Dammerung
Dammerung's Avatar
Do the mouldings come off easily?
Die Dämmerung..............when dusk began to fall, when dawn begins to break
Dammerung is offline   Reply With Quote
Old 02-10-2010, 10:38 AM   #20
slemmer
slemmer's Avatar
Pretty easy. The moldings fit by friction. You'll need to coax the molding off the bottom door's edge. I used a flat screwdriver to get at the top of the molding and a hammer to gently nudge the molding off the panel. To reinstall just line up one corner of the molding and wack it back on with your hand or soft mallet.
I was totally blown away at how much moisture is trapped within the molding. Now I know why the edges would rust out faster since there's no where for the water to drain. I think a better way to reduce the moisture problem is to drill numerous holes along the bottom of the moldings to allow for any moisture to drain away. It won't show since it'll be at the bottom of the door and will be hidden when the door is closed anyways. (I just talked myself into another Spring/Summer project!)
'04 645cic
'00 740i Sport
Old 02-10-2010, 10:53 AM   #21
Dammerung
Dammerung's Avatar
I have a feeling im going to join you on this project. I have rustophobia...terrible thing i tell ya ...
Thanks for the instructions. Going to check that asap.
Old 02-10-2010, 12:23 PM   #22
+1 on winter storage and rust proofing after getting the cancer removed!
Old 02-10-2010, 02:50 PM   #23
careless7
Drivin' new whips weekly
careless7's Avatar
Originally Posted by Dammerung View Post
It can be washed properly....all u need is a high pressure hose...i am aware of the problem...wash the car with a high pressure hose along the gap between the side skirts and doors...the high pressure creates a channel of water that takes all the salt out...its not water tht creates the corrosion..its the combination of salt and water....by the way i wasnt referring to your comment otherwise i would have quoted it....i meant it is a good idea to wash the car especially more often when driving in winter....there are other areas such as a pillers and fuel and brake lines that tend to get corroded in these cars aswell...
So salt creates rust and washing cars in winter is good...who knew?
careless7 is offline   Reply With Quote
Old 02-10-2010, 03:41 PM   #24
E36&8
E36&8's Avatar
I have done molding delete, so far the cancer been slown down.
I have always looked for a cure but its been too pricy
_____________________________________________
97 Hellrot, Remus exhaust, 3.73, AA SC, LTW Mods
E36&8 is offline   Reply With Quote
Old 02-10-2010, 09:04 PM   #25
Dammerung
Dammerung's Avatar
Washing them MORE OFTEN to get the salt off...and this is in reference to the design flaw...read the whole quote. It was a response to you regarding that washing it will create more problems than when its dry about the 740.
Old 02-11-2010, 01:25 AM   #26
slemmer
slemmer's Avatar
For those that drive their e38's all year I think a quarterly removal of the lower molding to wipe down the lower edge is a good thing to do. Also, I've been thinking about pumping a can of rust proofing product like CT's Formula 3000 or the Rust Check stuff inside the drain holes of the doors just so it will provide additional protection in the good and bad weather days. Of course, it's to be sprayed after a few warm dry days to ensure good coverage and spread.
'04 645cic
'00 740i Sport
Old 02-11-2010, 03:01 PM   #27
what is this molding delete you speak of? just took off that piece at the bottom where the water drains so that it just comes out on top of the skirts and out?
Old 02-12-2010, 04:34 PM   #28
E36&8
E36&8's Avatar
yes this will actually let the water to escape.
Old 02-13-2010, 11:42 PM   #29
do you have any pics of how this looks with the doors closed?
Old 02-14-2010, 03:01 AM   #30
slemmer
slemmer's Avatar
If you leave the moldings off the doors will look weird since they'll be an indentation where the trim would go.
'04 645cic
'00 740i Sport
