Old 02-01-2010, 02:25 PM   #1
hockeyfan27
hockeyfan27's Avatar
speed up your online gaming (and internet browsing)
This script is designed for WOW but I've seen some notable improvement with my web browsing as well. Read it for yourself: http://www.wowinterface.com/download...atencyFix.html
download link is there too.
Enjoy!
1998 328ic - Sold
hockeyfan27 is offline   Reply With Quote
Old 02-03-2010, 11:52 AM   #2
325isdan
what about downloading?
325isdan is offline   Reply With Quote
Old 02-03-2010, 12:00 PM   #3
hockeyfan27
haven't tested it for that, but I don't think it would. Its more about improved response time than gross speed.
1998 328ic - Sold
Old 02-03-2010, 12:03 PM   #4
Blades
Your opinion is to long
Blades's Avatar
right hand side of site. big letters where it says DOWNLOAD
if thats what you meant by download.
its for latency btw
-=[ BL/\DES ]=-
Old 02-03-2010, 12:37 PM   #5
bmdbley'sBro
wouldu like some tinfoil?
bmdbley'sBro's Avatar
checked site looks neat..
--off topic--
whats the best portal for torrents? and what else in a non windows firewall could stop torrents,
even if you allowed the torrent prog in the firewall prog?
Old 02-03-2010, 12:48 PM   #6
Jim .E.
E90 n00b
Jim .E.'s Avatar
Noticed a 4-7ms drop in latency on some servers. Internet browsing I wont notice a difference as I'm already getting 9+mbits consistently.
Old 02-03-2010, 01:17 PM   #7
hockeyfan27
most of the difference in browsing, I found, is the pages that previously did, don't wait for ads to load before other content.
--off topic--
I like torrentzap.com for most things - has a decent library.
What torrent program? Did you set-up port forwarding on your router? Does your router have access rules? (usu. secondary to the port forwarding, but can interfere)
1998 328ic - Sold
Old 02-03-2010, 01:27 PM   #8
Blades
Blades's Avatar
if you run mozilla get Ad Block Plus .. you wont even see an ad. It even gets rid of commericals that play before videos you watch on the net.
-=[ BL/\DES ]=-
Old 02-04-2010, 04:37 PM   #9
325isdan
its for latency btw
THat is not what I meant. OP answered it right after my post.
Old 02-04-2010, 05:01 PM   #10
bmdbley'sBro
thanks. actually meant Port, which ports are common. no router , just NIS2009 anti-V/firewall.
setup to allow b.torrent & checked other options in the firewall regarding tcp -udp &
still no torrents coming through..
Old 02-04-2010, 05:27 PM   #11
hockeyfan27
Originally Posted by bmdbley'sBro View Post
...which ports are common. no router , just NIS2009 anti-V/firewall.
there are hundreds/thousands of available ports that you can arbitrarily pick - it doesn't matter which you use (as long as it is not already in use).
I refer to this when assigning ports: http://en.wikipedia.org/wiki/List_of...P_port_numbers
Does the torrent program have a nat/firewall test built in? (I don't have any experience with b.torrent, just vuze and u.torrent, which both have a port checking feature)
Who is your ISP? Does your modem also provide your wireless internet?
Some modems are set up to function as routers like an all in one device. I had a bell modem I had to log into and configure to allow port forwarding, which I only figured out by doing a google search of the modem model number with "allow port forwarding" at the end. (nothing about that in the book that came with it)
1998 328ic - Sold
