Old 01-25-2010, 10:20 PM   #1
MLue1
MLue1's Avatar
Lightbulb Secondary Air Pump Rebuild
I found this Secondary Air Pump (SAP) Rebuild How-To, with the high cost of the SAP in Can$ it is an option for someone who has the tools and motivations to tackle the job.
http://forums.bimmerforums.com/forum....php?t=1320200
Mark
'99 E39 540iT
Old 01-25-2010, 10:43 PM   #2
Max_VQ
Max_VQ's Avatar
Nice post.... BUT I don't think most people have the special puller to remove the fan.
When my secondary air pump failed, I took it apart with a saw. Even with that, it was not easy...
If you try this, I wish you luck!!
Old 01-26-2010, 12:19 AM   #3
MLue1
MLue1's Avatar
Mine is toast so some day when I get around to it I'll let you know.
If someone does try it and is successfull, he could make a few $ helping others out, the last I checked the best price for one of these SAP was $375.
Mark
'99 E39 540iT
Old 01-26-2010, 12:46 AM   #4
Dado 540
Dado 540's Avatar
Hey Mark,
What are your symptoms with the pump being out or service? Any effect on the performance and fuel consumption?
E39 540i Sport
Old 01-26-2010, 12:52 AM   #5
I think i should have a few of them for sale...lol
Old 01-26-2010, 01:26 AM   #6
MLue1
MLue1's Avatar
Originally Posted by Dado 540 View Post
Hey Mark,
Hey Dado, the SAP is only used the first minute of start up,... I removed mine 2 years ago and put a big cork to cap off the hose I haven't noticed any difference in drivability, fuel consumption for my car in combined hiway and city driving, is usually over 450 km on 55 litres (with 315 read end), but a bit less in the winter depending on how many cold starts I do. The car passed with flying colors back in December, lots of zeros, I was surprised that they didn't even check for the SAP but then again how would they test it, the car was already warmed up.
Mark
'99 E39 540iT
Old 01-26-2010, 11:28 AM   #7
TheMadChigga
TheMadChigga's Avatar
Hey Mark, honestly, there isn't much point to change the secondary air pump, mine had thrown code regarding the secondary air pump for the first time back in like 06, I took it in, change the hose as it was cracked.
went away.
months on, came back again, so we thought it's the hose again, changed it, went away.
couple weeks later, came back on, this time everything seems to be fine, then I got irritated driving around with a CEL, feels like I'm driving a VW again.
so change the whole pump.
couple weeks later, came back again.
turns out to be carbon build up, that clogs the air passage, which at the point I decide to leave it, cause the only option I've got is take the heads off and clean it.
til this date, the pump still tries its best every morning and I still get about 600km per tank on the hwy.
Old 01-26-2010, 12:56 PM   #8
MLue1
MLue1's Avatar
Ya I don't intend to fix it for my sake but I'm think of selling her and the SAP is the only thing that's out of spec. If the fix is reasonable I will do it as well as change the valve so it can pass the safety.
All hiway driving, I get over 550 km on 55 litres, I never let the needle go below 15 on the gas gage. The Tourings have the 315 rear end so the milage is a bit less.
Mark
'99 E39 540iT
Old 01-26-2010, 01:07 PM   #9
Dado 540
Dado 540's Avatar
What about check engine light? Do O2 sensor codes come up?
E39 540i Sport
Old 01-26-2010, 01:12 PM   #10
TheMadChigga
you might want to watch out for the code coming up after you fixing it due to carbon build up, unfortunately a lot of 99 M62TU got the codes.
Dado, the O2 sensor won't throw codes since the secondary air pump's job is only to pump air for the first 30-90 seconds from cold start, the code is only directed at the pump itself.
Old 01-26-2010, 02:24 PM   #11
MLue1
MLue1's Avatar
Ya I get the CEL for the SAP, the O2 sensors monitor SAP, the fuel mixture and the CATs. Both my CATS are fine.
Mark
'99 E39 540iT
Old 01-26-2010, 02:33 PM   #12
TheMadChigga
wut.................... I've only gotten SAP code, not the other ones.
Old 01-26-2010, 02:54 PM   #13
MLue1
MLue1's Avatar
Your O2 sensors are fine, all i'm saying is that the O2 sensors monitor if the SAP is workin or not, The preCAt O2s monitor the mixture the post CAT O2s monitor the CAT.
How can you tell if the head is carboned up before hand?
If it is carboned up then you'd be right about not fixn the SAP.
Mark
'99 E39 540iT
Old 01-26-2010, 08:35 PM   #14
parm
Scarboro Mazda S&L
parm's Avatar
Nice find, I got one laying around will try this soon!
Old 01-26-2010, 09:30 PM   #15
TheMadChigga
I'm not too sure, but I *THINK* that you can do so by running vaccum check through the air passage.
