Old 01-25-2010, 12:28 PM   #1
awesM
Jet engine sound
Whenever I start the car up cold (i.e. mornings, parked for extended periods, etc.) it sounds like there's a jet engine spooling up. After the car warms up it stops.
Any ideas of what it could be?
Thanks in advance!
awesM is offline   Reply With Quote
Old 01-25-2010, 01:02 PM   #2
Fern3
formerly e36.M52B25
Fern3's Avatar
My guess is it's your secondary air pump. Pop your hood before you cold start your engine and listen to the top left part of your engine bay where the pump is. If it's coming from there then you have a vacuum leak somewhere that's why it stays on for longer than usual. Check connecting hoses and such
| M54B30/6MT Swap | KW V2 Coilovers |3.46 Diff |
|Genuine 19x8.5/9.5 Style 172M Wheels|
Fern3 is offline   Reply With Quote
Old 01-25-2010, 01:05 PM   #3
InfiniteDice
14 Years with the E30
InfiniteDice's Avatar
Either a belt or bearing... I'd look at alternator or water pump.
Bearings usually make that sound, belts tend to whine/screech
Press on the belt, if it drops more than 1/2 and inch then it needs to be adjusted. ( 2 pulley vs. 3 pulley belt have different deflection ranges, check a book) Look at the belt for glazing, the rubber will be shiney on the part that rides on the pulley, look for cracks in the rubber, it may need replacing.
Just noticed 36's comment, I'm not sure what an air pump is... but if your car has an air pump for some reason check that. LOL
Old 01-25-2010, 01:16 PM   #4
Fern3
formerly e36.M52B25
Fern3's Avatar
Lol any obd2 e36 has a secondary air pump that pushes more oxygen into exhaust gases to comply with emission limits.
Old 01-25-2010, 04:53 PM   #5
PedroBMW
Hooked on Boost
PedroBMW's Avatar
its the air pump for sure.
http://www.foldingtrailers.ca
Old 01-25-2010, 05:41 PM   #6
Mad Cow
Seriously?T hat is one of the greatest ideas I've ever heard, but how did BMW even get away with this? That would just dilute the mixture, not lowering the emissions in any way.
Mad Cow is offline   Reply With Quote
Old 01-25-2010, 05:52 PM   #7
Fern3
formerly e36.M52B25
Fern3's Avatar
Lol this idea was patented in 1966 and it wasn't by BMW. Obd2 emission standards were stricter than obd1 so most cars got an air pump installed after 1996, all it does is creates a more oxygen enriched enviroment and therefore combustion is fuller = cleaner emissions.
Old 01-25-2010, 06:17 PM   #8
^^why would the combustion be fuller if the secondary air pump blows air into the headers?
Old 01-25-2010, 07:16 PM   #9
Fern3
formerly e36.M52B25
Fern3's Avatar
I'm not really sure. I think it's cause the air that leaves the headers is still so hot that there is still some form or chemical reaction or combustion going on.. But that's just my guess
Old 01-25-2010, 09:06 PM   #10
BimmerDriver
Estoril Blau Member
BimmerDriver's Avatar
Send a message via MSN to BimmerDriver
Those are the turbos spooling up for sure man...
BimmerDriver is offline   Reply With Quote
Old 01-26-2010, 04:17 PM   #11
awesM
Thank you for you contribution.
Old 01-27-2010, 12:59 AM   #12
PedroBMW
Hooked on Boost
PedroBMW's Avatar
The secondary air pump reduces emmisions by decreasing catalyst light off time (the time it takes the cat to get to its operating temperature after a cold start.) The engine is purposely run over-enriched after the cold start so that the excess fuel (that wasn't burned in the cylinder) combusts with the air being pumped into the exhaust (specifically the catalyst brick), thus causing an exothermic reaction, ie. heat. This is pretty much standad on any car these days that is trying to attain the ultro low emmisons standards like PZEV, and will only become more and more used.
Old 02-13-2010, 01:59 PM   #13
awesM
Update: out of town for a couple days, and now she won't start. Can the noise be the cause?
Engine is turning over but it won't catch.
Going to look at the plugs...
Old 02-13-2010, 05:46 PM   #14
mclovin
I get that noise when car sits outside in -C
My noise is coming from the driver side of the engine and it goes away within a minute of a cold start.
mclovin is offline   Reply With Quote
Old 02-18-2010, 02:44 PM   #15
Eurotakeover
BMW Obsessed
Eurotakeover's Avatar
my 325i sounded like it had a turbo, then my exhaust cracked, now it sounds like it has a super charger apparently
Eurotakeover is offline   Reply With Quote
