Old 01-21-2010, 08:35 PM   #1
dil
dil's Avatar
HAS anybody used engine restore
just bought engine restore going to try it out as soon i do any oil change car has 200 000 km on it
Will it make a difference?
dil is offline   Reply With Quote
Old 01-21-2010, 09:08 PM   #2
BmW1819
i used it to reduce burning oil and so far oil level is good
Old 01-21-2010, 09:25 PM   #3
dil
dil's Avatar
do u know if it will fix oil pressure light
Old 01-21-2010, 10:15 PM   #4
blk3
blk3's Avatar
nope, thicker oil will. something like lucas
Old 01-22-2010, 12:26 PM   #5
BmW1819
the engine restore i used it's an MOS 2 is to to reduce friction . thicker oil will help pressure
Old 01-22-2010, 12:54 PM   #6
328IScreamer
328IScreamer's Avatar
i'm curous as to the results of this stuff
let us kiow!
Old 01-22-2010, 03:42 PM   #7
dil
dil's Avatar
im currently using 5w30 synthtic i use to use 0w 30 before wats a good oil viscosty to get rid of the light
Old 01-22-2010, 07:54 PM   #8
Is the oil pressure light on all the time? only when the car is cold? only when the car is warmed up? Only when you're idling and goes away when you hit the gas?
Old 01-23-2010, 12:22 AM   #9
dil
dil's Avatar
its on wen the car is warm and it flickerys and turns off or stays on till i give gas and goes away
Old 01-23-2010, 12:59 PM   #10
If that's the case you can try an oil with a higher hot viscosity rating if it's really bothering you, but you should check your owners manual when you see warning lights come up.
Old 01-23-2010, 01:01 PM   #11
dil
dil's Avatar
alright thanks for the help man
Old 01-23-2010, 01:37 PM   #12
dil
dil's Avatar
anybody else use it and notice a difference in acceleration
Old 01-27-2010, 01:06 PM   #13
dil
dil's Avatar
anybody ?
Old 01-28-2010, 12:54 PM   #14
dmytro
dmytro's Avatar
I used this stuff and I used 2 cans of it after changing it after about 1-2k intervals. First can was AWSOME! Last can I believe plugged the holes really good to a point that it felt very clogged. When I flushed that stuff and put in 10W30 oil (GTX from Wal-Mark for $8, 4L jug!!!!) it runs very smooth now.
My recommendation is don't put it in the winter! It will do no good it needs heat to stick to the cylinder walls, and start ups will be hard in winter. Also flush it out after a few 2-3K KM. But overall I think this stuff works.
dmytro is offline   Reply With Quote
