Old 01-21-2010, 12:18 AM   #1
mhamouda
Lookin like M
ABS locks, light is off
my abs light was on for the longest time but my abs/brakes worked completely fine, today my abs light went off.. but my brakes kept locking and i couldnt press the pedal
any input?
mhamouda is offline   Reply With Quote
Old 01-21-2010, 01:22 AM   #2
craigIS
A.K.A. crossfire291
craigIS's Avatar
im just pulling at straws, but have you checked your brake fluid?
flickr
Old 01-23-2010, 02:47 AM   #3
mhamouda
Lookin like M
fluidd is goood..
it started vibrating too much now, and making vibrating noises when i push the pedal and without..
but the ABS light is officially off ...
sometimes it would brake normal till i get to the bottom of the pedal then it vibrates
.. the obc doesnt say anything
Old 01-23-2010, 02:27 PM   #4
ScotcH
Does it come one at all when you start the car? Maybe the bulb just burnt out.
Old 01-23-2010, 07:20 PM   #5
pawcio
pawcio's Avatar
^ good point. or fuse.
in a '93 3 series is abs light linked to brake fluid sensor? i would think that the brake fluid is linked tp the parking brake light...but what do i know.
__
Old 01-23-2010, 09:09 PM   #6
mhamouda
Lookin like M
yeah it comes on when i turn on the car..
today it came on for 5 mins, and for those whole 5 mins the brakes worked perfect, no noises or vibrations
could it be a dirty sensor?
Old 01-24-2010, 11:20 AM   #7
pawcio
pawcio's Avatar
dirty or failing.
i had a faulty brake fluid sensor in another car before. the brake light was on the whole time even though the level was fine. I first thought it was the hand brake sensor and replaced that.
__
Old 01-24-2010, 06:18 PM   #8
Speed sensor on the wheels, abs control module.
Old 01-24-2010, 10:24 PM   #9
craigIS
A.K.A. crossfire291
craigIS's Avatar
check for leaks under the car. also look at the brake lines. i had a brake line burst on me, but before it did, my light was on, i had lack of stopping power, and there was a shuttering when i braked, i could also push the pedal to the floor, and not be able to stop hardly.
flickr
Old 01-24-2010, 11:37 PM   #10
mhamouda
Lookin like M
thanks for all your inputs,
I will check up on all of these and see
(Y)
