Old 01-17-2010, 08:05 PM   #1
Pit-E36sedan
Pls. help problem with JVC, KD-AVX40 deck
I just install deck replacing stock deck in my E36-1997-3.28 sedan and here are the issue:
1. No picture during playing DVD but it's reading and same thing with playing mp3 on the disk.
2. Can i bypass the connection from the e-break? And where to connect.
I'm wondering if this may be the reason why because i did not connect the wire to the e-break instead jump with remote wire but the FM radio is work fine.
Hope to hear from you guys thanks.
Pit-E36sedan is offline   Reply With Quote
Old 01-17-2010, 08:26 PM   #2
JUICY J CAN'T
propr'one's Avatar
AFAIK the e brake is ground, not positive. Try grounding it out instead, should work.
hid headlights
Old 01-17-2010, 09:28 PM   #3
Pit-E36sedan
Thanks for the reply but what do you mean by "grounding it out" connect the e-bbreak wire to the ground? I'm sorry i just wanna make sure if i understand it right. CAn you explain in detail if you don't mind.
Old 01-17-2010, 11:17 PM   #4
tg07lq
connect it to some thing that doesnt send electricity like the remote line does. connect it to the black wire in the harness or to a metal piece under the dash thats connected to the car body, sand any paint at the connection also
4cyl autotragic woes...
tg07lq is offline   Reply With Quote
Old 01-18-2010, 04:27 AM   #5
JUICY J CAN'T
propr'one's Avatar
Connect the lead from the HU that you would normally attach to the e-brake lead to a ground point (negative) IE. Negative battery terminal, any exposed part of the frame, etc.
hid headlights
Old 01-18-2010, 05:29 PM   #6
Pit-E36sedan
Thanks guys for your support... problem was resolved and it works.
