Go Back   maXbimmer Forums > Specific Regional Topics > Quebec/Gatineau/Ottawa
Old 01-09-2010, 08:17 PM   #1
Striker
Turbo Ready
Striker's Avatar
Precision O Ringing
After many tedious hours of machining, testing and tweaking the cylinder O Ringing tool I made, we did Adam's block which came out perfectly well. George made the grooves without a hiccup.
Many people complained that when their blocks were sent to be done at machine shops, the O Ring groove had a square finish at the bottom where the O Ring sat.
This is not good since the wire has room to move and will eventually sit lower on the block deck, reducing the clamping force between headgasket and the O Ring. This of course defeats the purpose of the O Ring making the gasket prone to failure again.
Regardsless what you use and how expensive it is, if its not properly done it WILL FAIL.
Not surprising, when we pulled Adams engine apart, his expensive MLS head gasket with what seemed to be Race Ware studs was blown three places!
This square bottom groove is unavoidable when a milling machine is used with an end mill to machine the O Ring groove.
The tool I designed and machined, cuts the O Ring groove to the exact same curvature of the O Ring wire used, so the O Ring fits tightly maintaining the exact clamping force between the head, head gasket and O Ring.
Two pics of the first two cylinders done.
SPEED AND POWER IS NOTHING WITHOUT CONTROL,
THANK HITLER, BMW HAS ALL THREE
Striker is offline   Reply With Quote
Old 01-13-2010, 05:08 PM   #2
bmdbley'sBro
wouldu like some tinfoil?
bmdbley'sBro's Avatar
So clean
Old 01-14-2010, 03:02 AM   #3
Manimillion
Photographer
Hey, what kind of machinery tools do you have at your shop?
Manimillion is offline   Reply With Quote
Old 01-22-2010, 01:07 AM   #4
Striker
Turbo Ready
Striker's Avatar
Originally Posted by bmdbley'sBro View Post
So clean
Replied to your PM Bro.
Old 01-22-2010, 01:07 AM   #5
Striker
Turbo Ready
Striker's Avatar
Everything Lathe, vertical/ horizontal milling machine, 3 angle valve grinding tool, O ringing tool which I machined with bearings, depth and diameter adjustment.
Drop by, its close to your house. How is your brother doing, where is your stang?[/quote]Drop by, its close to your house. How is your brother doing, where is your stang?
Email or call me, I don't get the time to surf the boards alot.
Old 02-04-2010, 06:29 PM   #6
The Sly
The Sly's Avatar
Email or call me, I don't get the time to surf the boards alot.[/quote]
Way to go Ralph...
hey i need to go and check that garage out soon.
Very happy to see what is going on at your location.
On my part, Just getting better and better everyday and i need to get some of the BMW blood into my veins and get my baby ready for the road fast.
not dead but actually getting better
The sly
The Sly is offline   Reply With Quote
