Old 01-08-2010, 09:02 PM   #1
craigIS
A.K.A. crossfire291
craigIS's Avatar
91-95 and 96-99 318 clutch, is there a difference?
As most already know, I have a 94 318is. I'm looking into getting a clutch kit and have discovered that there are kits for 91-95, and 96-99. My question: is there a difference, or can I use a kit for 96-99, or must I use a kit for a 91-95?
flickr
Old 01-10-2010, 03:06 PM   #2
craigIS
A.K.A. crossfire291
craigIS's Avatar
bump ttt.
flickr
Old 01-13-2010, 02:56 PM   #3
craigIS
A.K.A. crossfire291
craigIS's Avatar
bump....anyone?
flickr
Old 01-13-2010, 04:24 PM   #4
328IScreamer
328IScreamer's Avatar
almost positive there is
stick with your specified year
Old 01-19-2010, 12:40 PM   #5
jeffrie
Addict
jeffrie's Avatar
You can use any clutch you want provided you have the proper flywheel, clutch and P-plate combo.
So if you wanted a M5 clutch in the 318 then you need to change all 3 components.
I do know OBDII 318is have a deul mass flywheel that most shops will refuse to turn so will need to replace all 3 anyway which ='s to a 328 cluch kit for a upgrade at no additional cost.
Not sure about your OBDI counterpart but if a different part # then I would think that the flywheels may be different and not an interchangeable disk and or P-plate.
Old 01-19-2010, 03:39 PM   #6
craigIS
A.K.A. crossfire291
craigIS's Avatar
thanks. I think m gonna stay with what i know will work. just to be same.
flickr
