Old 01-06-2010, 08:41 PM   #1
Suprano
Suprano's Avatar
HID Question
Hey guys,
Quick question regarding my right side headlight and the fact the HID went out on me. Every time I turn the lights on it flickers a little bit, but fails to turn on. Should I go ahead and order the bulb or is possible that something else is up that has nothing to do with the HID???
If this is a common thing with e46s (I have an '02 325ci) then sorry for the dumb question, but it's my first one.
Rob
Suprano is offline   Reply With Quote
Old 01-06-2010, 09:50 PM   #2
dil
dil's Avatar
off topic question
can u install hid kit on oem headlight caseing and jus change the front plastic to glass ?(e36)
dil is offline   Reply With Quote
Old 01-06-2010, 10:51 PM   #3
Steve30
Techno Viking
Steve30's Avatar
The plastic housing are kinda small for fitting projectors in if that's what you're going to do. You cant change the plastic cover to a glass cover because the glass ones are bigger. Also for the OP's problem plug the bulb into the other ballast to see if it is the bulb or the ballast that is defective. HID bulbs very rarely go so I'm guessing that the ballast is blown.
Originally Posted by dil View Post
off topic question
E36 ///M3 S54
STock 335i "The Punisher"
Old 01-07-2010, 05:48 PM   #4
kkeddy
if it flickers most likely its not the bulb, it would either be the ballast or the ignitor..
2003 BMW 325i (sold)
2010 Civic Si (track) (sold)
2001 BMW e46 m3 (current)
kkeddy is offline   Reply With Quote
Old 01-07-2010, 06:04 PM   #5
Gamite
Gamite's Avatar
Flickering can be the bulb, I've had a bulb go out like that before.
Easiest thing to do is swap the bulbs, that will tell you if it's bulb or ballast.
www.gamite.net
Old 01-08-2010, 11:24 PM   #6
Suprano
Suprano's Avatar
Thanks guys. I'll check it out this weekend and see which it is.
Rob
Old 01-09-2010, 02:43 PM   #7
kkeddy
i have a set of d2c bulbs 8k for sale if you need. check my fs thread
Old 01-09-2010, 04:08 PM   #8
Hey bro,
Sounds like the typical early e46 dead ignitor problem. Swap the bulbs left to right, if the problem stays on the same side you need a ballast.
Old 01-09-2010, 07:27 PM   #9
I'm having a similar problem. Ivan, do you have anything that can plug-in to my OEM setup as straight plug and play?
Old 01-09-2010, 07:35 PM   #10
Yep, there's a PnP option but you lose bi-xenon. There is a full aftermarket replacement that is plug and play and keeps bi-xenon functionality, however its not cost effective vs. replacing the ignitor from BMW. (ignitor is 260$ afaik)
Old 01-10-2010, 06:18 PM   #11
I don't have bi-xenon functionality to begin with so I should be fine with your PnP option. Could you PM me the cost/details?
