Old 01-04-2010, 10:34 AM   #1
mclovin
Whistle at startup
Morning everyone,
Recently when we'v been having -10 weather these days, i'd get a loud whine/ whistle from the engine bay at cold startup. Sound goes away after few minutes of idling. Dont know if this would help or not but also theres this burnt smell coming from exhaust when its cold. Things i'v changed so far are idle/adjust pulleys and both belts. Any ideas?
mclovin is offline   Reply With Quote
Old 01-04-2010, 10:57 AM   #2
harman_rai
325Xi Executive Pkg
harman_rai's Avatar
i have the same problem and i had my belts and pullys changed last year
harman_rai is offline   Reply With Quote
Old 01-04-2010, 02:09 PM   #3
Common problem, its from the auxilary air pump...they start to whine when they get old. They only work at start up, so noise goes away soon. Chances are it will stop working soon!
Old 01-04-2010, 02:17 PM   #4
mclovin
Realy? Car has only 80k on it tho lol
Old 01-04-2010, 07:36 PM   #5
slemmer
Driving in the fast lane
slemmer's Avatar
So what happens if the aux air pump fails? Is it only for emissions?
'15 Ford F150 Lariat SCSB 4x4
'04 645cic
'00 740i Sport
Old 01-04-2010, 07:43 PM   #6
Steve30
Techno Viking
Steve30's Avatar
yea for cold start emissions
E36 ///M3 S54
STock 335i
Old 01-04-2010, 10:14 PM   #7
richie_s999
My 325is is making that noise and also finding some weird vacum leaks at cold temps too, can hear them under the hood and seem to be coming from around the pump. All goes away once it is warmed up. Would make sense it's around that air pump with the cold weather. Hope to get some time next weekend to look at it
Old 01-05-2010, 10:39 AM   #8
mclovin
*Update
So i had a time to pop the hood this morning after starting the car. Sound isn't coming from the pump area, its coming from the drivers side. Its either alternator or adjust pulley which has been changed 3k ago. Most likely alternator. Is there anyway of getting rid of it without having to replace the whle alt?
Old 01-05-2010, 11:30 AM   #9
InfiniteDice
14 Years with the E30
InfiniteDice's Avatar
Alternator most likely.
Old 01-05-2010, 11:34 AM   #10
mclovin
And theres no way of diy replacing the bearing in it huh. best bet is to live with it or replace it with new one
Old 01-05-2010, 12:03 PM   #11
uber e36
uber e36's Avatar
I bought a rebuilt alternator from a guy in MTL that is/was a vendor here on the boards...
Old 01-05-2010, 12:43 PM   #12
Also check power steering pump, it sits in the same area...and they can make noise at cold start up.
Old 01-06-2010, 01:15 PM   #13
BmW1819
it's sounds like your alternator pulley really easy to change . 16 wrench/socket out she comes stick a screw driver and put your ear on it when the car is running make sure u don't drop the screw driver and have a listen or poor small amount of water on it should go away for 5 seconds if it was changed 3k there is 3 pulleys on your car did they change all 3?? to elimate the ac pulley put on your ac and see if the noise get louder
Old 01-06-2010, 04:11 PM   #14
mclovin
Pulley? I thought its the alternator bearing that goes, which is inside the alternator.
The last pulley is by the a/c and the sound isn't coming from that area.
Old 01-06-2010, 07:19 PM   #15
BmW1819
u change the tensioner/ pulley and alternator pulley?? alternator at 80,000 that shitty
