Old 01-02-2010, 11:42 PM   #1
pawcio
pawcio's Avatar
Question help needed. my first CEL.
so i've looked at some posts on the forum as well as did some research on google and got some conflicting information. i will now dip into the cumulative knowledge of maxbimmer for some advice.
i got a cel. let's not go into the reason for it (might be a thread topic for another day). i think the problem has been solved, but i'm now assuming that the cel stays on whether or not the problem remains until it is reset. am i correct?
is resetting a cel in an e46 only possible by using an obdII scanner? if so, what is a reasonable price to pay for it being done. if not (*fingers crossed*)is there a manual way to do it?
thanks for any informative help in advance.
__
Old 01-03-2010, 12:05 AM   #2
If you unplug the battery, it should clear it, assuming the problem was fixed...and its not airbag light, those have to be reset from what i remember!
Any OBDII scanner should be able to do it, if you are ever in the area, stop by i can do it for you...takes 5 sec!
Old 01-03-2010, 02:39 PM   #3
pawcio
pawcio's Avatar
^ thanks for the info. luckily tho, this afternoon i had to go out and i realized that the cel was gone when i started my car. so i have a new theory. is it possible that the ecu resets the cel after it cycles through its regular checks and the original problem is fixed or gone?
__
Old 01-03-2010, 02:53 PM   #4
325isStephen
Drifter
Depending what kind of code it is. For instance a sporadic misfire may go out when the car is not misfiring. However if there was to be an open circuit aka cut wire going to a coil, the light would remain on due to it being a hard fault.
Old 01-16-2010, 09:56 AM   #5
nachos23
SweetXi
nachos23's Avatar
I had both an OBDII scan reader and Carsoft. I can diagnose and reset virtually any CEL code. If ya wanna hook-up and have it checked let me know....
Old 01-17-2010, 03:32 PM   #6
pawcio
pawcio's Avatar
thanks for the offer, but all is good, and the cel was caused by something minuscule anyway. there wasn't actually anything wrong.
__
Old 01-18-2010, 12:57 AM   #7
arsevader
CEL may go off, But the code will probably still be stored. You can get it read and cleared for free at Partsource. Or better yet get a Peake Tool.
It's well worth the cost believe me.
'85 325e
'90 325i
'02 325it
'03 320i
'96 Volvo 850R
arsevader is offline   Reply With Quote
Old 01-29-2010, 01:54 AM   #8
carthik
so its common for the CEL to go off after it has been on? Does the ecu store all codes even if the CEL goes off or only certain ones. I had the light come on and off and every time I decided to get it pulled the light was gone. I waited till it finally stayed on till I got to the mechanics to get it pulled, stupid me.
1986 Toyota Trueno GTV
1988 BMW M3
1990 Nissan Skyline GTR
1990 Yamaha YSR 80
1991 BMW 318is
1994 Acura Integra GS-R
1999 Honda Civic SiR
2000 BMW 323Ci
2003 Derbi GPR50R
carthik is offline   Reply With Quote
