Old 12-30-2009, 05:42 PM   #1
heretic
93 318is cranking but not starting
Drove home from work Boxing day morning. Had to drive through a huge puddle. Battery light came on, think car kind of slowed, then all was good. Can't remember if I drove the next day or not, but then when I went to start it, would crank but no start.
Main relay - voltage at terminal 30 and 86
Fuel pump relay - voltage at terminl 30, voltage at 86 when key on
still have to check fuel pump
crankshaft position sensor reads 580 ohms between pins 1 and 2; Bentley manual says 1280 +/- 10 but internet says Bentley may be wrong.
What do you think ? ECU cooked ? Any advice ?
heretic is offline   Reply With Quote
Old 12-30-2009, 06:16 PM   #2
Ceeker
Crank pos sensors are common for e36's- check the connections to see if water leaked in causing it to malfunction. also always check the fuses.
1 90 325is white - keepin
1 87 325i vert -red - keepin
KEEPER 88 5sp Vert 2016
Old 12-30-2009, 09:38 PM   #3
heretic
fuel pump is working; pulled cover off and turned over; sounded like it might catch so kept cranking for 2 - 3 minutes and it started with foot to the floor. HMMM. I'll see what happens tomorrow.
Old 12-31-2009, 01:44 AM   #4
rdtx2005
this maybe out in left field..
how about the starter?
rdtx2005 is offline   Reply With Quote
Old 12-31-2009, 01:49 AM   #5
aaron320i
Send a message via MSN to aaron320i
Engine is turning over. Starter is fine.
aaron320i is offline   Reply With Quote
Old 01-03-2010, 03:47 PM   #6
heretic
Everything is fine now. I've been driving it for days now and always starts on first crank. Big puddle must have just got something temporarily wet or I just flooded it.
