Old 12-29-2009, 05:07 PM   #1
autodrjr
1995 325is totally stock.
autodrjr's Avatar
Send a message via MSN to autodrjr
Nos
ok so just curiosity... anyone here use nos?
what mods have you done if any?
any adverse effects ( beyond the obvious)
input is appreceated
thanks
1995 325is M mouldings, 17 inch M5 wheels, clear lenses all around, fresh motor (mine)
1995 325i vert. Lowered, 18 inch M rep rims, intake, smoked lenses all around, hid's, angel eyes, intake, strut bar, m3 mouldings. plus tonnes more. (moms)
autodrjr is offline   Reply With Quote
Old 12-30-2009, 12:07 PM   #2
taxi615
I have been using nos for the last 5 years. Never have I had any problems well my mercedes 2 years ago had plug issus but I put in a set of Zex plugs and problem solved.
I have a 4-6cyl Zex wet kit and it comes pretty much with all you need to be safe the reste is up tp the driver. you need to keep a good head on your shoulders for this. If you want extra safety then go to http://www.zex.com/ and you'll have loads of little parts that can help keeping your head on the right way...lol...it can be loads of fun but if used the right way. I'm using it in my curent M3 got 2 bottles in the trunk (one is gone to fast) and I'm giving it 100 shot of NOS and it seams to love it (I went to the dyno shop to make sure air fuel was good and all after each new jet was installed) make sure you get a a good a/f meter so you are aware at all times what is going on under the hood.
Also make sure you get colder plugs for your car I use the zex plugs very good price and they work great.
Will you see a big diference OH YEAH!!! my benz was doing 14.9 1/4 (heavy car even if it had 236hp) and with 100 shot it went down to 13.6. Havent tested the M3 yet but compared to my freinds E46 M3 I'm far enough in front (he actually had no chance at all...lol)
if you need more info or what not send pm or if it's relavent to the post send it here I will answer the best I can.
happy holidays
taxi615 is offline   Reply With Quote
Old 12-30-2009, 01:10 PM   #3
autodrjr
autodrjr's Avatar
any information on the sniper kit from holly? thats the one i have been kind of eyeing up for now.
Old 12-30-2009, 01:13 PM   #4
sof220
I've used it in the summer, make sure to advance your ignition a couple of degrees or you will warp your head gasket! Like I did Was also using the ZEX wet kit. The bigger the nozzle you use the more advanced?? the ignition should be. Better to use an after market ignition coil/pack.
sof220 is offline   Reply With Quote
Old 12-30-2009, 03:41 PM   #5
autodrjr
autodrjr's Avatar
good thought... i was also told i shouldnt run a chip and nos... anyone know anything about that? i just want to make a super informed decision before i order the kit
Old 12-30-2009, 04:08 PM   #6
taxi615
I don't recommed a chip with nos
Old 02-03-2010, 12:59 AM   #7
2slow4door
Send a message via MSN to 2slow4door Send a message via Yahoo to 2slow4door
I thought you were supposed to retard the ignition...
2slow4door is offline   Reply With Quote
Old 02-03-2010, 03:28 PM   #8
Darkness95m3
Darkness95m3's Avatar
I used it on my supercharged M3. Had no problems until I broke my belt which resullted in a cracked head.
Old 02-03-2010, 11:30 PM   #9
aaron320i
Send a message via MSN to aaron320i
I do not recommend this mod. Too many risks.
and darkness, what car did you have that the belt broke?
aaron320i is offline   Reply With Quote
