Old 12-28-2009, 01:10 AM   #1
k1zzle[tt]
One BMW fixed, the other has a problem.. Help please..
I fixed my older 323I with the EML problem, which costed 2000.00 at BMW and now 1 week later my other car a 2002 325I has a serious issue. If anyone has any insight please post.
I drove my car for about an hour today everything was fine. I parked the car for about 2 hours, came back outside and the instrument cluster didn't work. Even without turning the car on, when i switch the lights on, the instrument cluster does not light up., when i turn the car on the parking brake and the brake pad light comes on and then disappears. the speedo doesn't work, the fuel gauge doesn't work, non of the needles work, although the speedo worked for a little bit when i took it for a test drive. There are no strange noises with the car, doesn't seem like it runs any different, but the cluster either flickers or doesn't work at all. What could it be, i am stumped. I did check the fuses in the glove box, the 3 fuses seemed to be good., Is there anything else I should check? Should i put in the cluster from my 323I to my 325I to see what happens?, I don't want the tampering light to come on either. PLEASE HELP, I just forked out 2000 dollars... *
k1zzle[tt] is offline   Reply With Quote
Old 12-28-2009, 01:35 AM   #2
ca12lo
ca12lo's Avatar
Step 1. Stay as far away from the dealership.
Step 2. Take it to RMP.
Step 3. Post on max how quick and cost-effective Rocco fixes your problem.
(FYI: RMP is a max sponsor)
ca12lo is offline   Reply With Quote
Old 12-28-2009, 01:39 AM   #3
k1zzle[tt]
That would be my obvious choice if I cant fix it myself. I'm not asking for directions to the nearest shop, I'm asking for a solution to my problem.
Old 12-28-2009, 01:54 AM   #4
Bliss
Administrator
I'm not aware of there being any relay or anything else for the cluster so it appears that the cluster or the harness' might be your problem. I would first try and unplug the cluster, take it out, clean all the connectors. Make sure there's no corrosion or anything from moisture or water, and plug it back in and test. I think that should be your first step.
For maxbimmer decals, and t-shirts, email info@maxbimmer.com
Old 12-28-2009, 01:59 AM   #5
k1zzle[tt]
Will do first thing in the morning.. although there is one thing bothering me.. when i checked the fuses in the glove box, the three fuses to check were circled by the previous owner. I think I may have problem, Ill update you guys tomorrow.
Old 12-28-2009, 02:06 AM   #6
Bliss
Administrator
Hopefully there's no underlying electrical problem that you're not aware of that the previous owner was. Good luck, keep us posted.
Old 12-28-2009, 02:13 AM   #7
Steve30
Techno Viking
Steve30's Avatar
The soldering on the cluster can break apart causing the malfunction. This is a common issue with BMW's (or at least E36's).
E36 ///M3 S54
???whp E30 coming soon.
Steve30 is online now   Reply With Quote
Old 12-28-2009, 08:49 AM   #8
richie_s999
You can add e30's to the list with the same problem.
richie_s999 is online now   Reply With Quote
Old 12-28-2009, 09:38 AM   #9
ca12lo
ca12lo's Avatar
I don't mean to crap on your thread but you spent as you stated close to $2000 paying someone else to get the following fixed:
-throttle body and all assembly parts 1186.59
-stage two diagnostics 254.00 I belive it was 2 hours.
-wiring harness 276.67
With taxes it cost:
1940.50
AND....now you want to diy an electrical problem in your BMW, don't believe everything you read on the internet. Just saying....
GL though!
Old 12-28-2009, 09:53 AM   #10
Ceeker
I know this sounds pretty silly to say but we always seem to miss the obvious. Which is why it doesn't seem obvious. PLEASE check your fuses. You just might have one that's blown. my few "cents" worth. :-)
2 IX's -sold and parts
2 325i 4 dr - sold
1 87 325is red - parts
1 89 325i vert grey - parts
1 90 325is white - keepin
1 87 325i vert -red - keepin
Old 12-28-2009, 09:58 AM   #11
nachos23
SweetXi
nachos23's Avatar
I have a copy of Carsoft. If there's an internal fault in one of the modules, then maybe Carsoft will "see" the problem. It's likely a mechanical fault (wiring harness or related), but maybe Carsoft might identify the source of the problem.... PM me if you want it scanned.....
Old 12-28-2009, 10:49 AM   #12
MANDD
Autobahn East
Before you do anything,
disconnect the cluster wait 30secs then reconnect or disconnect both battery terminals off and away from battery. Touch terminals together for 10sec.
Reconnect to battery and carry out functional check.
If you need local assistance call 905-686-2700
Mark.
Old 12-28-2009, 01:48 PM   #13
PrettyFreddy
aka Donut Police
PrettyFreddy's Avatar
he DID CHECK the fuses
on topic: +1 on what what Bliss said. As with electrical issues, if it's intermittent you can place your bet on loose or corroded connection. It's a safe and affordable bet to lose but big to gain
PrettyFreddy is offline   Reply With Quote
Old 12-28-2009, 02:57 PM   #14
k1zzle[tt]
I think I'm having some sort of progress once I did what MANDD suggested. The Cluster now lights up completely, before it wouldn't or would flicker, now its solid. But now i have no mileage on my car, the speedometer goes to 280kmph and most of the lights are illuminated. The Cluster reads PPPPP. I'm assuming I have to get the car reset?
Old 12-28-2009, 04:43 PM   #15
MANDD
Autobahn East
So far so good.
At this point you will need to reset the cluster via the tester.
Swing by tomorrow and I will reset it for you.
Mark.
