Old 12-27-2009, 07:26 PM   #1
fabolous
BMDUBZ!
fabolous's Avatar
Speedometer is acting up! help!
My speedometer had been acting up hasn't been the case for months but prior to that the problem was occuring then went away now its acting up again!
By that I mean while driving the needle on the speedometer will drop down to zero!
Just curious i notice it affects the reading on my milage.
just wondering wats the prob here and what need to be fixed or replaced? and how much?? rougly!
thanks
Fabolous!
fabolous is offline   Reply With Quote
Old 12-31-2009, 07:26 AM   #2
jeffrie
Addict
jeffrie's Avatar
Sounds like the speed sensor in your diff died, it's a simple fix.
Old 12-31-2009, 11:06 AM   #3
Ceeker
if it is your speed sensor, then you just unplug wiring from the diff and unbolt it. part cost about 40-60.00 bucks new from dealer. I'm sure plenty of guys on here have a used one to give.
1 90 325is white - keepin
1 87 325i vert -red - keepin
KEEPER 88 5sp Vert 2016
Old 01-02-2010, 09:53 PM   #4
fabolous
BMDUBZ!
fabolous's Avatar
thkns im sure its prob the speed sensor! ill look into getting it repalced thanks again!
Fabolous!
Old 01-04-2010, 09:18 AM   #5
98Dinan3
98Dinan3's Avatar
Is it just the speedo, or that whole half of the cluster? Intermittent failure is of the cluster is fairly common on the E36. I'm on my third... Anywya, if you find it's not the speed sensor, grab a used cluster.
Old 03-29-2010, 12:01 AM   #6
BMW-Parada
BMW-Parada's Avatar
Speedometer problem :P
You know what boss we used to have a 94 BMW 318I with the same problem but it happened after we disconnected the battery because we went away on vacation so honestly it might be either Lack of a code like ours was or maybe Humidity got into a sensor or something wich causes it to not work properly.
BMW-Parada is offline   Reply With Quote
