Old 12-29-2009, 11:06 PM   #16
NOTORIOUS VR
NOTORIOUS VR's Avatar
Originally Posted by thinair View Post
That's a great way to kill a centre diff.
Explain how he would hurt the center diff by doing that.
E36 ∑ DYNO ∑ TUNING ∑ WIRING ∑ PARTS
Old 12-29-2009, 11:27 PM   #17
^^the viscous coupling gets way too hot if you put too much torque though it for too long. Overheated VC's can fail very quickly.
Old 12-29-2009, 11:40 PM   #18
thinair
moderationistismingly
thinair's Avatar
As Ivan stated it would kill the VC from overheating. Not because of the load, just because of the probability that one axle (more than likely front) would probably rotate more than the other. Like taking a quick stab at the e-brake won't mess anything up (unless you crash), but holding the e-brake for a long slide can.
"Driving is like a narcotic, an addiction that can take over lives. It ruins people, breaks families apart, and even kills. Itís habit that needs to be fueled. Time, money, rationality, sweat, knuckle skin, and anyone who disapproves are of little importance to a driver, and are often overlooked. Hi, Iím Nelson, and Iím a drivaholic."
Old 12-30-2009, 01:18 PM   #19
NOTORIOUS VR
You're sure they didn't account for that already? Would seem kind of strange to me if they didn't. How common are diff failures in Subarus?
Either way I'm glad I have a mechanical diff and don't need to worry about that...
Old 12-30-2009, 01:26 PM   #20
thinair
thinair's Avatar
The viscous coupling is only used for limited slip, so when it fails you don't lose the centre diff technically, just the ability to distribute torque to the front and rear wheels. The torsen in the Audi's is superior though.
Old 12-30-2009, 02:14 PM   #21
NOTORIOUS VR
That's a little bit of a confusing statement IMO.
If the center diff is of a VC unit, then a broken center diff will fail to lock which in turn will not send power to the slipping wheels. And I'm guessing the Subaru's are FWD biased? If it is, it won't be able to send power the rear wheels. If it's RWD biased it would be the other way around. Either way you would loose the use of the center diff totally.
Old 12-30-2009, 02:26 PM   #22
thinair
thinair's Avatar
Sube's aren't fwd based (there are older exceptions with auto trannies), they're symmetrical. Think of it as a rear LSD with worn clutches will act as an open diff, this would be the same with a damaged VC. It would just send more torque to the slipping axle, just like how a 2wd car with an open diff would send more torque to the one slipping wheel.
As a note the newer STi's are torsen based.
Old 12-30-2009, 03:25 PM   #23
NOTORIOUS VR
I don't get it... from a technical standpoint, if the VC were damaged it wouldn't be able to 'lock' or engage the clutches, thus not allowing a power transfer. And since the center diff is what transfers the power back/front, one set of axles wouldn't get any or minimal power.
Old 12-30-2009, 05:01 PM   #24
thinair
thinair's Avatar
A VC never locks, just like a clutch pack never locks (without some electronic intervention anyway). They just prevent 100% slip. On a BMW for example with a clutch pack in the rear diff, you could launch and still have one rear wheel spinning 2-3 times faster than the other.
Old 12-30-2009, 09:15 PM   #25
NOTORIOUS VR
A VC diff locks. Not 100% but the action of it transferring power from one shaft to the other is the act of it starting to lock up.
We're talking about the same thing just differently I think.
