Old 12-22-2009, 02:32 PM   #1
craigIS
A.K.A. crossfire291
craigIS's Avatar
Car makes noise when tunrining....whats up with this?
Since it has got cold out, my 94 318is has been making a whining noise when i turn, and it seems to be coming from the drivers side. This doesnt happen all the time though.
Could this be power steering, or maybe water pump? any suggestions as to what it could be?
flickr
Old 12-22-2009, 03:02 PM   #2
MiroE36
MiroE36's Avatar
I got rid of my noise by flushing the system and putting in new fluid. If that won't work for you, have the belt checked before you look into the pump
Old 12-22-2009, 03:08 PM   #3
parm
Scarboro Mazda S&L
parm's Avatar
Leaky power steering lines sucking air, try to re-clamp all connections, or at reservoir. GL.
Parm
Old 12-23-2009, 02:48 PM   #4
Darkness95m3
Darkness95m3's Avatar
Low fluid, also the cold makes it worse until the vehicle heats up
Old 12-23-2009, 03:05 PM   #5
328IScreamer
328IScreamer's Avatar
depending on the noise and where it's coming from it could ver well be a wheel bearing
does it do it when turning to one side but not the other?
Old 12-23-2009, 03:22 PM   #6
lvan
lvan's Avatar
Low power steering fluid for sure. That is when you turn it in the morning and let it idle for a bit in neutral. Had a same issue with my 318i (M42).
Old 12-23-2009, 04:05 PM   #7
Ceeker
Check all the above mentioned; also serpentine pulley; they are known to seize and can also make noise intermittently.
1 90 325is white - keepin
1 87 325i vert -red - keepin
KEEPER 88 5sp Vert 2016
Old 12-24-2009, 01:43 AM   #8
craigIS
A.K.A. crossfire291
craigIS's Avatar
at first i only noticed the sound when i turned left, but i have come to notice that it really doesnt matter which way i turn.
ill start tomorrow by checking the fluid level.
flickr
Old 01-01-2010, 04:40 PM   #9
craigIS
A.K.A. crossfire291
craigIS's Avatar
i just want to be sure that i have the location of the power steering reservoir correct. located near the front on the drivers side, says ATF only?
flickr
