Old 12-17-2009, 01:58 PM   #1
bimmerjoe
Yagerbombs/skanks
bimmerjoe's Avatar
Auto Page Remote starter
Two XT-33 Five-button remote transmitter with S.A.W. technology
Optional XT-11 One-button ultra Mini remote for remote start. Mini remote can be added to factory remote key chain. S.A.W technology
New Negative and Positive (- & +) Door Lock Outputs
New C3 compatible with Data Link port
New 2-Way Serial-Data port for iData modules
New Window-mount super heterodyne SAW receiver. RX-300A
New Ultra small unit size with Micro K relays
New Dash mounted LED and Valet switch
New GM starter timing for no start wire vehicles
Relays on-board: Parking lights, Starter, Accessory, Ignition #1, Ignition #2
Output for Ignition #3
Temporary Stop Feature (short stops with the engine running/no key)
200ma ground programmable output for horn or factory security rearm
Programmable one pulse or three pulse start for adding-on to an existing aftermarket or factory security / keyless entry system (includes programming for shock sensor bypass)
NEW Programmable factory keyless door locking before & after start
New Programmable Ignition control door locks (on / off)
New Programmable Safety Start - Two or One push on the start button
Programmable for gasoline or diesel engine
Programmable for remote start: voltage type, RPM/Tachometer learning type or timer checking type
Programmable Low or High check level
Programmable run time: 5, 10, 20, or 30 minutes (default=20 minutes)
Programmable Parking Light output: constant or flashing for visual start confirmation.
asking $120
Call my cell 647 242 0869. Its brand new in the box.
1999 323i-sold
2001 540i M- Sport
bimmerjoe is offline   Reply With Quote
