Old 12-17-2009, 06:29 AM   #1
Yorkie
Yorkie's Avatar
A wierd electrical problem
This started a couple of days ago, when the temp really dipped.
When I start my car, I get a really loud squeel sounding like a belt. At the same time, the ABS and ACS lights flicker in the dash and the radio cuts out. It will last about 20 seconds.
Then sometimes when I brake, the squeel and flicker both come back under braking and go away about 20 seconds after I accelerate.
I can't for the life of me think how the two could be connected.
Battery is only 3 yrs old, checked voltage while running, 13.0.
Any thoughts?
Yorkie is offline   Reply With Quote
Old 12-19-2009, 11:51 AM   #2
autodrjr
1995 325is totally stock.
autodrjr's Avatar
Send a message via MSN to autodrjr
ya charging seems low.... should be 14.4 or so. sounds like your belt slip is causing issues and if it doesnt charge full out it will make the car electrical act funny
1995 325is M mouldings, 17 inch M5 wheels, clear lenses all around, fresh motor (mine)
1995 325i vert. Lowered, 18 inch M rep rims, intake, smoked lenses all around, hid's, angel eyes, intake, strut bar, m3 mouldings. plus tonnes more. (moms)
autodrjr is offline   Reply With Quote
Old 12-19-2009, 05:05 PM   #3
richie_s999
does the noise sound like its coming from the bellhousing/through fire wall, I am having some weird isues at low rpms that go away with acceleration (one being rough idle) I think my altenator's low output is messed causing the problems.
Old 12-19-2009, 11:17 PM   #4
ScotcH
Well, my first guess would be the alternator. Squeeling might be the bearing, and it's causing it run slugish?
