Old 12-16-2009, 09:05 AM   #1
rdtx2005
battery or alternator?
I've been having this strange issue lately. The battery did not hold charge over night, but a quick boost will get the car started. So, i decided that it probably was the battery. i got a new OEM battery, charged it, put it in the car; now two days later, the car won't start in the morning. could it possibly be the Alternator this time?
This is totally frustrating
rdtx2005 is offline   Reply With Quote
Old 12-16-2009, 09:21 AM   #2
Get your electrical system load tested, it will tell you if it's the alt.
Otherwise it could be a leak causing your bettery to die overnight. Do you have an alarm or a stereo system?
Old 12-16-2009, 09:32 AM   #3
Ceeker
test electrical system for draw as stated above- ie stereo system or even a ground short.
1 90 325is white - keepin
1 87 325i vert -red - keepin
KEEPER 88 5sp Vert 2016
Old 12-16-2009, 10:28 AM   #4
ShortShifter
Sex Wagon
ShortShifter's Avatar
Most likely your alternator bud...E36 are known for this. You can get a used on for pretty cheap from Tom or Fil. Or get a new one for around $200
Originally Posted by alpine86 View Post
Do we really need an Ipad???
Originally Posted by BigD View Post
Only if you have an iVag.
ShortShifter is offline   Reply With Quote
Old 12-16-2009, 10:30 AM   #5
rdtx2005
stock stereo. I read about slow battery drain issues.. but that would be like very hard to find.
Old 12-16-2009, 11:19 AM   #6
E36is
'OldSchool..'
E36is's Avatar
if you have the 18 button OBC, you can quickly test to see if the alternator is bad. When my battery light came on, i did this test and sure enough the OBC was registering 11.21VDC while the car was running. usually it will show 13.84VDC on the OBC.
Old 12-16-2009, 11:11 PM   #7
rdtx2005
update: I have tested the alternator. it's ok.
omg.. electrical........................................ ....
Old 12-16-2009, 11:25 PM   #8
lvan
lvan's Avatar
How old is the battery?
Old 12-17-2009, 01:02 AM   #9
slemmer
Driving in the fast lane
slemmer's Avatar
If the bat is new and good and the altenatoris good, I'd check the amperage draw to see if there are any parasitic drain, e.g. trunk light etc. Went through a couple of batteries before I did that test and on another car and it turned out to be a faulty trunk light switch that kept the light circuit lit.
'15 Ford F150 Lariat SCSB 4x4
'04 645cic
'00 740i Sport
Old 12-17-2009, 11:15 AM   #10
jeffrie
Addict
jeffrie's Avatar
Check the ground, Nascar318is had an issue like this.
When he would start the car 12V, rev it up to about 5K rpms then 13.7V.
Then would randomly turn off shortly after and occasionaly back on.
Old 12-17-2009, 04:08 PM   #11
rdtx2005
2 days
Old 12-17-2009, 05:02 PM   #12
Ceeker
check glove box light, trunk light. it is most probably a very slow draw. Can happen to any car. or any aux accessory such as a stereo. Even check the ground from the motor to the body. Alt to the motor.
Old 12-18-2009, 08:04 PM   #13
rdtx2005
I have narrowed it down to either the radio or the AMP... took fuse 9 (radio) out and no more drain...
damn
