Old 12-13-2009, 10:12 PM   #1
Brent
Brent's Avatar
LF: Power Steering Rack
Hi Everyone,
My power steering has never worked, so I put on a belt and filled up the reservoir today. Unfortunately, the leak seemed to be coming from the rack. I have it just about off, so I guess it's time to look for a replacement.
Does anyone have one for sale?
Thanks,
Brent
Brent is offline   Reply With Quote
Old 12-13-2009, 10:58 PM   #2
SamE30e
SamE30e's Avatar
Try one of the forum sponsors, they usually have one kicking around.
85 325 - Turbo M52B28.
Old 12-13-2009, 11:52 PM   #3
richie_s999
pm'ed
Old 12-14-2009, 02:48 PM   #4
dmytro
dmytro's Avatar
While you are at it do an upgrade to e36 rack.
dmytro is offline   Reply With Quote
Old 12-14-2009, 03:27 PM   #5
molotova
molotova's Avatar
Send a message via MSN to molotova
Eurostyle Brent i got a good from him couple weeks back or simplycars maybe
molotova is offline   Reply With Quote
Old 12-16-2009, 09:44 AM   #6
Brent
Brent's Avatar
Thanks, guys, got it!
Old 01-01-2010, 01:08 AM   #7
CaptainGomes
did you upgrade to an E36 rack or stick with an E30 rack?
CaptainGomes is offline   Reply With Quote
Old 01-01-2010, 10:03 AM   #8
Brent
Brent's Avatar
Stuck with e30, also replaced inner and (about to replace) outer tie rods as well while I was at it
Old 01-01-2010, 12:24 PM   #9
CaptainGomes
ah too bad, I was hoping for another opinion on upgrading. I hate my E30 rack!
Old 01-10-2010, 11:45 AM   #10
towfield
towfield's Avatar
is the e36 rack a direct fit or does some mods have to be done and what is the advantage ie a better ratio? Also can you just bleed the rack and run with no power steering ?
towfield is offline   Reply With Quote
Old 01-10-2010, 01:42 PM   #11
Ceeker
the rack fits but you have to use spacers to make it mate to the body. you also have to shorten the steering knuckle as the output shaft housing is taller then the e30. I wouldn't recommend running a power rack dry. it's meant to hold fluid for a reason. the turn ratio with a stock e36 rack is a bit shorter then e30 but you can even go shorter with an M3 e36 rack. All depends on how you drive and what you prefer. one of guys know the spec difference between the rack. I can't recall.
1 90 325is white - keepin
1 87 325i vert -red - keepin
KEEPER 88 5sp Vert 2016
Old 01-10-2010, 04:05 PM   #12
towfield
towfield's Avatar
thanks so It is a quicker steering, could work for me for the rallycross that I am doing. I look for the info on the how to install it. its on here somewhere I would think
Old 01-10-2010, 07:21 PM   #13
There is a decent writeup on r3vlimited how to do the E36 rack swap. It is in the FAQ section.
