Old 12-13-2009, 12:32 PM   #1
Petinko
Rusted Frame WTF now?
so I was jacking up my 1998 328i to swap a front right caliper, and noticed that the jack pad was caving in.... i removed the side skirt and found the rot.... as I started cutting out the rotten sheet metal I took a look inside and found the jack support had completely torn away from the frame... so I guess the frame is rotten!
heres the question can this shit be repaired??? has this happened to anyone?
Petinko is offline   Reply With Quote
Old 12-13-2009, 01:13 PM   #2
v_bimmer
Jailbait FTW
v_bimmer's Avatar
e36's are known for rocket panel rust.......shops can cut it out and weld a new one in!
Old 12-13-2009, 01:25 PM   #3
Dr. Flyview
"Mint"
Dr. Flyview's Avatar
Lol I don't think he's talking about the rocker panel... He's talking about the frame that's within the rocker panel at the jack points.
1998 BMW 328is - summer
1993 BMW 525i - daily
1994 BMW 325i - sold
1992 BMW 325i - gone
sold
Old 12-13-2009, 02:37 PM   #4
rdtx2005
common problem.. happened to me too
rdtx2005 is offline   Reply With Quote
Old 12-13-2009, 02:41 PM   #5
richie_s999
Its usually just the metal at the bottom, the inner struckture should be fun, you can get it fixxed, I just finished weling a patch on the winter car in the same spot today
Old 12-13-2009, 03:38 PM   #6
Petinko
So you guys think it can be fixed? like I said the jack point ti completely f-ed, the thing tore away from the frame.... i'm not talking only about sheet metal on the rocker panel I meant the frame with-in the panel itself... can/has a fix been done?
Old 12-13-2009, 06:13 PM   #7
blk3
blk3's Avatar
it can be fixed, if old muscle cars can be resurected then im sure that can be repaired.
Old 12-13-2009, 08:36 PM   #8
Petinko
^^^^ the same thing went through my head when it happened. It they can restore old shit then why not mine... I don't know of where though... there arn't many BMW people where I'm from... I'd probably have to go to TO for that.... if anyones got a name or Number then PLEASE hook me up!
Old 12-14-2009, 03:48 PM   #9
Darkness95m3
Darkness95m3's Avatar
Easy fix.
Old 12-14-2009, 04:45 PM   #10
Petinko
got a quote today from a top-notch bmw repair shop... 1500$ not bad considering the damage... I only have 98K on the car so its worth saving for sure!
Thanks again guys I was sort of freaking out when this shit happened!
Old 12-14-2009, 05:14 PM   #11
lvan
lvan's Avatar
wow
1998 and you got that issue? No wonder why you have E30 for a back up lol.
