Old 12-11-2009, 06:29 PM   #1
hustler
hustler's Avatar
Style 32 Repaint
I have some staggered style 32's that are in terrible condition. Apparently the PO had no pride in the appearance of his vehicle (but had all of the service done, with receipts, which is amazing). I am planning on using these just for winter rims, so they don't need to be perfect however I still want them to look nice. As far as I am concerned, anything would be an improvement over the current condition of the rims. The tires on them are almost totally bald cheapo summer tires, so I didn't even have to mask them off.
The process started with lots of scuffing/sanding and existing paint removal. The really curby areas needed a little sanding just to take the roughest part of the edges off. That made a big difference. I can't believe how little the factory paint was adhered to the rim - most of it just peeled off very easily. I mostly used a red 3M pad to rough up the surface for primer. The first coat of primer got sanded a bit to take down the big bumps, then a second coat to even it all out.
I went with Duplicolor black wheel paint. Started off with two light coats, then a heavier one. After letting the paint set up I went over again with a couple of coats of clear, to try to protect them as much as possible from salt. Duplicolor has a wide range of colours available for wheel refinishing. I have matte black on my Jeep, and it looks badass too. I think glossy suits this car better.
Total materials are in the $50 range, with about 3 or 4 hours of time. Way cheaper than buying new wheels, and also way cheaper than getting them powdercoated nicely. As far as I'm concerned a wheel refinishing-caliber project should be done really well, or really cheaply. If they were in better shape from the beginning I might have gone for really well.
I am letting them dry totally before I get my winter tires put on early in the week. Stay tuned for after pics!
Here are the before pics:
1998 E39 540i 6 Speed
hustler is offline   Reply With Quote
Old 12-11-2009, 07:09 PM   #2
carjoe
carjoe's Avatar
Awesome project. I found some 32's locally and can't decide if I should buy them or stcik with the 5's...
Make sure you post the after pics!
93 325is - sold!
2000 540ia- sold!
Old 12-11-2009, 07:45 PM   #3
Dado 540
Dado 540's Avatar
did you end up checking out that store?
E39 540i Sport
Old 12-12-2009, 12:15 AM   #4
JINT
JINT's Avatar
niceee !!! you got a rare wheel there
Old 12-12-2009, 12:19 AM   #5
hustler
hustler's Avatar
I like how they look on the car too, I might even end up with them on in the summer.
Old 12-12-2009, 01:00 AM   #6
blk3
blk3's Avatar
hey lets see some finished pics. curious to see how they look on the car.
Old 12-15-2009, 10:13 PM   #7
hustler
hustler's Avatar
Here's a really crappy pic, I will get more tomorrow once there's light and after I go to the tire shop. I took these freshly painted (unbalanced), summer tires
out for a spin around the block and it was not nice. Getting the winter tires on tomorrow will be a step up! The unbalanced part didn't seem to make the car shake ... weird, because there were definitely a few weights on there that I popped off for the repainting.
Old 12-15-2009, 10:56 PM   #8
Dado 540
Dado 540's Avatar
Hustler, i just noticed your sig and by far the best! hahah
Rims looking good!
E39 540i Sport
Old 12-16-2009, 12:10 AM   #9
hustler
hustler's Avatar
Rims looking good!
Thanks! I will post a real photo in the next couple of days.
I bet I have some pretty interesting mods on my car - I see a lot of guys using only "BMW Factory Approved Techniques" to fix stuff.
Old 12-17-2009, 02:50 AM   #10
rzrdxl
You've inspired me to refinish my winter set M5 Reps which look worse than your Style 32's before pics!
+1 on the best sig!
rzrdxl is offline   Reply With Quote
Old 12-17-2009, 12:02 PM   #11
hustler
hustler's Avatar
Do it! It's not that hard, and makes them look a lot better.
Old 12-17-2009, 12:26 PM   #12
Blades
Your opinion is to long
Blades's Avatar
I did this a while back .. make sure you clear coat the shit out of them .. it prevents it from getting paint chipped off from road debris.
-=[ BL/\DES ]=-
Tags
paint, refinishing, wheel
