Old 12-10-2009, 06:37 PM   #1
dil
dil's Avatar
Cooling issues agian!
2 weeks ago replaced thromostat after that realized (hg) is leakin but guna fix tht in the spring car starts cooling down wen in high revs only it overheats in traffic
ANY SUGGESTIONS
CLUTCH FAN MAYBE ?
dil is offline   Reply With Quote
Old 12-10-2009, 06:37 PM   #2
dil
dil's Avatar
and no heatt !
Old 12-10-2009, 06:56 PM   #3
Darkness95m3
Darkness95m3's Avatar
Could be;
Clutch fan
Air Pocket in cooling system
Pluged heater core
Faulty control panel
Old 12-10-2009, 06:59 PM   #4
dil
dil's Avatar
could anybody diagnose it for me cuz i dont wanna start putting money in to
Old 12-10-2009, 07:00 PM   #5
dil
dil's Avatar
bleed the air everyday in the morning still no differance
Old 12-10-2009, 07:31 PM   #6
dil
dil's Avatar
Old 12-14-2009, 10:26 PM   #7
autodrjr
1995 325is totally stock.
autodrjr's Avatar
Send a message via MSN to autodrjr
its got air in it every morning?
1995 325is M mouldings, 17 inch M5 wheels, clear lenses all around, fresh motor (mine)
1995 325i vert. Lowered, 18 inch M rep rims, intake, smoked lenses all around, hid's, angel eyes, intake, strut bar, m3 mouldings. plus tonnes more. (moms)
autodrjr is offline   Reply With Quote
Old 12-15-2009, 08:59 AM   #8
sproule905
sproule905's Avatar
keep bleeding it and adding coolant.. then once that's complete move onto the next trouble spot..
Old 12-15-2009, 05:53 PM   #9
dil
dil's Avatar
Sorry boys too late to trouble shoot blew the expansion tank hoses which ruptured the plastic plug it goes in
Old 12-15-2009, 05:57 PM   #10
dil
dil's Avatar
any reason why it would get blown off (expansion tank Hose) from the top of the expansion tank the small hose
Old 12-15-2009, 05:59 PM   #11
Ceeker
yeah! you have too much air in the system and the pressure built up to the point that it blew.
1 90 325is white - keepin
1 87 325i vert -red - keepin
KEEPER 88 5sp Vert 2016
Old 12-15-2009, 06:53 PM   #12
k1zzle[tt]
My expansion tank also blew in the summer, to be specific, it was the little screw on the top of the expansion tank, after I replaced it, I believe the part was 30$, I never had cooling issues again. This was on my 2000 5spd 323I. You could have a more servere problem, then just air pockets, I'm guessing it's either the water-pump malfunctioning (electrical problem) or you have a clogged heater core.
The only other thing I can think of is electrolysis. Here is an example of what it can do, hence it not cooling properly unless you make the belts work very fast (adding gas).
k1zzle[tt] is offline   Reply With Quote
Old 12-15-2009, 06:54 PM   #13
dil
dil's Avatar
it was not tht hose it was the smaller one tht goes from the expansion tank to the rad
Old 12-15-2009, 06:55 PM   #14
dil
dil's Avatar
thanks for the help guys keep it coming tho still tryin to figure out wat happened
Old 12-15-2009, 06:58 PM   #15
dil
dil's Avatar
it was the small hose from the expansion tank to the rad
