Old 12-07-2009, 09:04 PM   #1
synergy141
Rear Harmon/Kardon speakers are blown , what are good speakers I replace Them with?
My two rear h/k speakers are blown in my 98 m3. Im looking for new speakers that are as good or better than the stocks. What do you guys recomend?
PS . I have an Alpine CDA-9884 Deck and an Alpine M500 amp with
12" Alpine Type S sub.
synergy141 is offline   Reply With Quote
Old 12-08-2009, 03:22 PM   #2
bigfeller
Propeller Head
bigfeller's Avatar
Power?
Are you running the rear speakers off of your Alpine deck directly, or will you be using the BMW amp?
Jarrod
'97 M3
SOLD- Now Enjoying Honda Civic
bigfeller is offline   Reply With Quote
Old 12-08-2009, 05:05 PM   #3
synergy141
Ill have them hooked up to the factory bmw amp.
Old 12-08-2009, 05:22 PM   #4
bigfeller
Propeller Head
bigfeller's Avatar
Ahh...
The H/K 6x9s are 2 ohms, if memory serves, which is what the BMW H/K amp is expecting to see. Your typical aftermarket car speakers are 4 ohms impedance.
If you hook up a 4 ohm speaker to your H/K amp, with the doubled impedance, your speaker will only see about 12-15 watts of clean (less than 5% THD) power from the amp, so it really doesn't matter what you pop back there- they will be running at well below their power capacity.
As for audio quality, these are rear fill speakers, and the amp has a built-in cross-over which will send the woofers ONLY mid/ low frequencies. You need therefore be concerned with only three things; efficiency (how loud they go for a given amount of input), size (you need a 6x9), and cost (as little as possible).
Jarrod
'97 M3
Old 12-08-2009, 06:40 PM   #5
synergy141
What do you think of the Alpine Type R 6x9's? , do they have better sound quality than the factory H/K's ? .
Old 12-09-2009, 11:59 AM   #6
bigfeller
Propeller Head
bigfeller's Avatar
Type R
The Type Rs will be just fine. As I mentioned, if you're running them off of the stock H/K amp, anything will do. As for sound quality, they will sound better than your stock H/Ks, though they will probably be a bit quieter (due to their higher impedance). If the price is right, go for it- they'll provide nice fill to bridge the gap between your fronts and sub.
Jarrod
'97 M3
Old 03-30-2010, 07:27 AM   #7
tominizer
IF you run a 6x9 that's more efficient then the factory, even though it has a higher impedance, should not notice much of a difference. Why don't you get yourself into a 4 channel amp and give the whole system a boost ?!!?!?
Tom
Current : 2013 Mini Countryman JCW, 2007 Z4M Roadster
Past: '88 E30 M3, '69 BMW 2002 Ti, 2000 328i, Audi A6 TT, BMW X5 3.0i , Audi A4, Mini Cooper Clubman S 1.8T
Old 03-30-2010, 09:21 AM   #8
nachos23
SweetXi
nachos23's Avatar
The best for your BMW.... Bavarian Soundwerks http://www.bavariansoundwerks.com/
My Rides:
2009 335Xi
520HP
H&R coilovers
BBS LM wheels
//M sport package
BMW Personal Audio System
2000 Z3M
Conforti tuned
AFE CAI
++More to come this winter
Old 05-22-2010, 06:20 PM   #9
iverson03tj
iverson03tj's Avatar
isnt bsw only good if you dont want to by-pass the crossover and/or amp?
never knew setting up a good sound system could be so hard
Tags
alpine, harmon, kardon, speakers
