Old 11-20-2009, 08:24 PM   #16
Sorry, same as the 92-95 Getrag and damn similar to the 96+ ZF.
Old 11-20-2009, 08:40 PM   #17
Then why does everyone dyno e36's in 4th? Wouldn't it make more sense to do it in 5th?
Old 11-20-2009, 08:42 PM   #18
Steve30
Techno Viking
Steve30's Avatar
i think 5th exceeds the speed at which most dynos become unsafe. i was reading about this a few weeks ago on bf.c
E36 ///M3 S54
STock 335i
Old 11-21-2009, 12:12 AM   #19
kruler
Kruler, i didn't want to ask this before the item sold, because i didn't want to affect the sale.
Is there any performance reason for a 6th gear? IIRC the 5th gear on ZF e36 transmissions is already overdriven, and the rest of the ratios are the same, correct?
This would probably be a great mod with a shorter geared diff, like a 3.64 or something.
There is not a noticeable difference through the first 5 gears between the two gearboxes. The overdriven 6th gear allows you to run a high ratio diff without sacrificing top speed or fuel economy on the highway. The getrag is also a much stronger tranny than the ZF and shift much nicer. The shifting is almost identical to that in an E39 M5.
kruler is offline   Reply With Quote
Old 11-21-2009, 12:14 AM   #20
kruler
Originally Posted by Steve30 View Post
yep, ratios from 1-5 are the same. it's just the addition of overdrive. also if i recall correctly, the 6 speed is a sealed unit so you cant change the fluid vs the 5 speed having the drain and fill bolts.
false, the 6 speed is not sealed and takes ATF
Old 11-21-2009, 12:20 AM   #21
kruler
i hope you have a reliable supply of these, i have plans
I have a reliable supply on a per order basis, I am not regularly bringing them in for sale. If you have plans for one, plan on one month from the date your deposit is left (30%)
This one came with an engine that was ordered by a customer
Old 11-21-2009, 12:21 AM   #22
Steve30
Techno Viking
Steve30's Avatar
i always thought it was sealed for some reason.. even more of a reason to get one i guess. do you come across these euro parts once in a blue moon or do you have regular access to them? if i can gather some more coin this winter i would like to get a 6 speed since my input shaft bearing is on its way out anyways.
edit: ^ answered my question.
E36 ///M3 S54
STock 335i
Old 11-21-2009, 10:17 AM   #23
That, plus governors with stock software.
