Old 11-13-2009, 03:37 PM   #1
David
Still too early for winter tires?
Do you guys think it's a good time for mounting winter tires? Based on the calendar, it's the right time to put them on. But the weather is unseasonably warm. There are going to be some days next week with day time highs above 10 degrees. I'm afraid of prematurely wearing out the rubber in these temps.
I'm supposed to put mine on next week but am thinking I should maybe hold off until daytime highs peak at 5 degrees.
What do you think?
1997 318i
Boston Green Metallic with Beige cloth interior
15" Steel Wheels with Plastic Hubcaps
Administrator on DetailersClub.com
David is offline   Reply With Quote
Old 11-13-2009, 06:06 PM   #2
ScotcH
no problem at all ... if it was like 25 or something I'd worry, but 10-15 is nothing.
Do you drive in the mornings or at night, when it's 0 or below? There's your answer.
Old 11-13-2009, 07:29 PM   #3
Euro
I put mine on last weekend when it was comfortable to work outdoors.
Euro is offline   Reply With Quote
Old 11-13-2009, 07:47 PM   #4
98Dinan3
98Dinan3's Avatar
mine are going on this week
Old 11-13-2009, 08:18 PM   #5
Mine is going on this weekend.
Unless I get lazy...
Old 11-13-2009, 08:19 PM   #6
Junaid
mine will go on the day it snows
Needs more mods
Junaid is offline   Reply With Quote
Old 11-13-2009, 08:31 PM   #7
Dysantic
Captain Chaos
Dysantic's Avatar
I'm holding out hope. I may have to buy a beater SUV for a job and if that happens I'm just gonna store the car and then leave the summers on. If the job falls through I will probably put them on at the end of the month.
Old 11-14-2009, 12:15 PM   #8
Just registered my beater today, M3 is parked tomorrow. Finally.
Old 11-14-2009, 12:19 PM   #9
King Luis
The King.
King Luis's Avatar
seeing the temperatures for the next week, i'm planning on changing next weekend...even though i've been saying that the last 3 weeks.
Mods: TBD.
Sold:2004 Silver Gray M3
Gone:1990 Brilliantrot 325is
Old 11-14-2009, 12:44 PM   #10
David
Thanks to all for the replies.
I do drive in the mornings and evenings when the temps are cooler. So mounting them now does make sense.
I'm like you. Been checking the temps every week and holding off. Not that I'm complaining though. It can stay at 10 degrees as the daytime high all through winter if it wants to!
1997 318i
Old 11-14-2009, 04:26 PM   #11
pawcio
pawcio's Avatar
i put mine on yesterday evening. yeah its still warm in the middle of the day but normally one drives to work morning and back evening or late afternoon so the temp is probably closer to if not below 7 degrees.
i also wanted to do it this weekend because its not as fun working on a car when its cold outside. the temp is gonna drop in a week or two anyway so changing to winters now is ok.
__
Old 11-14-2009, 05:47 PM   #12
vladvm
you wear out your summers more, put those winters on!
vladvm is offline   Reply With Quote
Old 11-14-2009, 07:51 PM   #13
pawcio
pawcio's Avatar
+1...save the summers for the summer.
__
Old 11-14-2009, 08:38 PM   #14
Dissembler
Dissembler's Avatar
I put mine on several weeks ago cause they had no tread left after doing A LOT of donuts because I needed a good reason to put my winter tires on because my summers needed 15psi of air every 12 hours cause the tire bead and sidewalls were ripped from donuts and auto-x...
Old 11-15-2009, 04:11 PM   #15
Gonna be putting the winters on the V70 R next week, unless I get lazy
