Old 11-11-2009, 10:13 PM   #1
Steve30
Techno Viking
Steve30's Avatar
just finished m50 manifold
Hey guys, I just finished my M50 manifold swap today. I Started the car up and everything was perfect except for a slightly louder top end ticking. Is this due the the engine running lean until it adapts to the new air flow? Also, i got a check engine light as soon as i got on the highway. my brother said it could be the MAF due to the new airflow. any help would be appreciated
thanks,
steve
E36 ///M3 S54
STock 335i "The Punisher"
Old 11-11-2009, 11:07 PM   #2
let everything adjust, see how it is tomorrow
Old 11-11-2009, 11:13 PM   #3
Steve30
Techno Viking
Steve30's Avatar
hopefully thats why the CEL came on. As for the ticking, I think its the injectors. Apparently they are loud as hell without a fuel rail cover on. I'll update this tomorrow.
E36 ///M3 S54
Old 11-11-2009, 11:45 PM   #4
blk325i
blk325i's Avatar
the ticking is normal, there should be no CEL, scan it, most likely a vaccum leak
blk325i is offline   Reply With Quote
Old 11-11-2009, 11:57 PM   #5
+1 on the vacume leak! They can be very sensative to vacume leaks, triggering the CEL. Reset the light and see if it comes back.
Old 11-12-2009, 12:01 AM   #6
Steve30
Techno Viking
Steve30's Avatar
i guess its time to invest in the peak engine tool
E36 ///M3 S54
Old 11-12-2009, 01:36 AM   #7
iverson03tj
iverson03tj's Avatar
Was it an easy swap? did u use a kit or found the parts urself?
Old 11-12-2009, 05:29 PM   #8
Steve30
Techno Viking
Steve30's Avatar
i bought the manifold from eurostyle and i used eric's kit from m50manifold.com. the install is very straight forward. the biggest problem i had was the manifold bolt in the back. labelling all the harnesses helps a ton. it took me about 7 hours by myself.
do you think a cracked/ripped intake boot would cause the CEL? I used the original one which did have some tearing. I'm going to BMW tomorrow to buy a new one.
E36 ///M3 S54
Old 11-13-2009, 05:21 PM   #9
iverson03tj
I dont think it Should. Do you know anyone that can tell u the code?
Old 11-13-2009, 05:37 PM   #10
Steve30
Techno Viking
Steve30's Avatar
My friends brother does have a code reader but I haven't had a chance to talk to him yet. I read that any leak post-MFA would throw off the CEL and cause the engine to run lean. I really dont see what else it could be. Every vacuum line is in place.
E36 ///M3 S54
Old 11-13-2009, 09:01 PM   #11
BmW1819
a cracked intake boot after the air flow meter is a vaccum leak and will through a lean mixture code
Old 11-13-2009, 09:52 PM   #12
Steve30
Techno Viking
Steve30's Avatar
I thought so. I ordered the boot from bmw but it wont be in until monday. Will I still need to have the CEL reset with the tool or will it correct itself?
E36 ///M3 S54
