Old 11-10-2009, 10:57 PM   #1
jamison67
E30 POWER
jamison67's Avatar
Results of my stomp test
hey guys,,,,so i did the stomp test on my 88e30 convertible cause it has not been runnin proper and here r the results,,,,,,i need help figure out,,cause i dont under stanad the diagram givin when i google stomp test,,,,so this is what the check engine light did
it went blink,pause,blink,blink,pause,blink,pause,blink,pa use,then blinked and stayed on for like 4 sec and then started to repat itself,,,,if anybody nows what code that might be and can help me out that would be great
jamison67 is offline   Reply With Quote
Old 11-10-2009, 11:25 PM   #2
SamE30e
SamE30e's Avatar
1211
1211 - DME, Motronic computer, related fault - which may indicate problem with car computer itself. Delete any stored codes and perform following test: Start the car and let it run for 30 seconds; Turn off car and let it sit for another 30 seconds; Perform diagnostic test again; If the same flash code re-appears DME should be replaced
85 325 - Turbo M52B28.
Old 11-11-2009, 02:49 AM   #3
jamison67
E30 POWER
jamison67's Avatar
did that test and the problum is still there,,,,,so i guess i need to get one does anyone have one for sale
a few questions,,,,will any e30 dme work or will i need to particular on for my model,,,and also i have a stroker motor and it has a markd chip in it can i just swap this chip with out a problum,,
thanks
Old 11-11-2009, 09:06 AM   #4
simplycars
simplycars's Avatar
I should have the ecu - pm if interested
simplycars is offline   Reply With Quote
Old 11-11-2009, 09:58 AM   #5
SamE30e
SamE30e's Avatar
You need a 173 ecu (out of a 325i).
Pretty readily available.
Old 11-11-2009, 01:04 PM   #6
jamison67
E30 POWER
jamison67's Avatar
parts
and wit the 173 its compatible wit the stroker markd chip i have i will be able t use that wit no problums
Old 11-11-2009, 07:47 PM   #7
You need to determine whether your car has a 153, or 173 DME. And no the chips are not interchangeable between the two.
Old 11-11-2009, 08:16 PM   #8
jamison67
E30 POWER
jamison67's Avatar
so this means thaat i am going to have to tottaly retune my car,,,i cant just take the one chip out of mine and put it into the new one
Old 11-11-2009, 09:57 PM   #9
Maybe not, again, it depends what computer is in your car. Then once you figure that out, find the same DME as a replacement, and the chip can be swapped over.
Old 11-15-2009, 04:10 PM   #10
jamison67
E30 POWER
jamison67's Avatar
well bad news,,,,,i picked up another ecu this weekend and put it in and performed the stomp test again and it came up again that the dme was a problum,,,,,couls it be that there is a problum with something else wiring or something and its not the ecu,,,,,,this is driving me crazy ,,,,if anyone can give me a hand in what u think that would be great
thanks
