Old 11-09-2009, 12:34 PM   #1
adam325i
adam325i's Avatar
Winter Projects?
Hey guys,
Winter is here, cars are getting put away.
Wondering what everybody elses plans are for the winter todo onto there car.
I know i got a list going like
replace timing belt and water pump.
recover front seats
buff since the new paint job
Clean up the rims
paint and instal spoiler
repaint mirorrs.
ive got a long list going,
what are your plans this winter?!
Adam
90 325i 4dr Winter fun
90 325i 2dr Summer/track car
87 325i 4dr Parts
adam325i is offline   Reply With Quote
Old 11-09-2009, 01:05 PM   #2
- new struts / shocks
- new sways
- remove rear subframe
- ss brake lines
- front BBK
- weld in rear camber / toe plates
- new gas tank (or find leak and fix)
- remove interior, inspect floor, repair anything necessary
- remove floor tar
- paint headliner black
- paint carpet black
- install e36 steering rack, reinstall power components
- reduce WG spring tension, install boost controller
- build front light bar for aux lighting
- inspect front suspension parts, replace as needed
I need to make an offical list somewhere so I don't forget stuff.
Old 11-09-2009, 01:15 PM   #3
LOL put e30 away for winter? Ha.
My list is install winter springs and shocks (stock e30 m3 stuffs)
Stock rims on winters
Change steering wheel to stock M Tech
Winter mats
Unplug antennae
and a good Oil spray for rust proofing.
Old 11-09-2009, 01:30 PM   #4
SamE30e
SamE30e's Avatar
Paint... or boost...Wheels and tires.. don't know yet.
85 325 - Turbo M52B28.
Old 11-09-2009, 01:58 PM   #5
dannyb
M50 refresh + swap
e36 steering rack
new gas tank
sway bar bushings
dannyb is offline   Reply With Quote
Old 11-09-2009, 02:52 PM   #6
Well the turbo project is being stashed away but it's in a spot where I can't work on it, so that's got to wait until next spring. The DD is going to get #19 injectors + M30 AFM + cone filter + MarkD chip setup and maybe a throttle body bore. I did a DIY undercoating this past weekend, turned out pretty good we'll see how it holds up, winter tires are ready to go when it starts getting consitently cold, all you guys who put your winters on already are probably hating this 15 degree weather lol.
Old 11-09-2009, 02:56 PM   #7
cormier
cormier's Avatar
Get a window knob...
all brake lines
S52 swap by summertime
Re-paint windshield trim and mirrors
Find 2 front koni struts + my rear two
Old 11-09-2009, 03:23 PM   #8
New balljoints, RSM's (and probably subframe bushings)
Raise it 3 inches (back to stock)
mabye fix e-brake?
Old 11-09-2009, 04:09 PM   #9
supernaught
supernaught's Avatar
For the IX TOURING(That I picked up on Saturday )
To-do list(completion goal of July)
all new upholstery, black cloth with a special touch
Carpet and headliner are going black.
25-30% tint all around
Full respray in diamantschwarz metallic
Smoked euro smilies and tails
blacked out kidneys
window trim is already black out!!!
Volvo lip(**** the haters, I like it)
Coilovers(H&Rs to start)
Billy HDs
e36 m3 offset CABs
Short shifter c/o richie
e36 steering rack and adapter
front driveshaft spacer
SS braided brake lines
Stock rotors, ceramic pads
Manual -> power sunroof conversion
mudflaps
undecided on the sound system
17" silver w/ polished lip bbs RX style wheels with 215s
front strut bar
skid plate and shield
MarkD chip
I'll be rebuilding the M20 with all new seals and gaskets, headers, still undecided about the 272/284 cam M30 AFM, 19lb inj, and cone I have in my other IX.
But I need opinions:
All black: valve cover, intake mani, plug wires, calipers, shift/ebrake boots?
Black with some blood red: crimson valve cover, intake mani, wires, calipers, and blood red stitching on black leather boots and steering wheel?
Old 11-09-2009, 07:56 PM   #10
Brent
Brent's Avatar
Fix power steering
fix e-brake
inner tie rods
alignment
new tires
paint rims
complete bodywork
red paint job
Brent is offline   Reply With Quote
Old 11-09-2009, 08:22 PM   #11
cormier
cormier's Avatar
Reds always a nice touch, so long as its not too much more than stitching and valve covers
Old 11-09-2009, 09:27 PM   #12
E30M42cab
Parts Hoarding Specialist
E30M42cab's Avatar
The winter project list is basically everything I didn't get around to doing in the summer.
Just like Rudy, I've gotta winterize the car:
I've installed the wires and switches for heated seats.
Install cloth heated seats and rear ski pass.
Winter mats.
Snow are going on next weekend.
Pull off the Hella and Autopal lights and go back to sealed beams.
"i" lip replaces "is" lip.
Then I've gotta buy all this crap for the spring for a fast all-in-one weekend install.
Poly rear shock mounts
Slotted front discs and racing pads
R-comps and rims
IE springs
Front strut bar
Rear subframe bushings
Rear control arm bushings
Grow up and move on.
Old 11-09-2009, 09:49 PM   #13
Nick_V
Nick_V's Avatar
on the 540i:
pull motor/tranny, install new clutch/JB flywheel, upper oil pan gasket, rear main seal, find/fix power steering and coolant leaks, adjust steering box, new water pump, install euro smilies (will probably go HID as well) and GC coilovers as a gift to myself/victory lap if I actually accomplish everything above without ****ing anything up....
Old 11-09-2009, 11:58 PM   #14
davericher20
black and blue
davericher20's Avatar
blacked out kidneys
Billy HDs
e36 m3 offset CABs
mudflaps
front strut bar
MarkD chip
whoooweee, sounds awesome man, do the red accents in the engine bay for sure! post some pics!
Old 11-10-2009, 12:17 AM   #15
e30_kid89
The Afro-stig
e30_kid89's Avatar
Oh boy..where could i start...
-New megasquirt box w/anti-lag
-possibly #60 injectors for big-boy boost next year
-wiring clean up(not a priority)
-My rack officially shiat the bed so probably an e36 rack swapshizzle
-Id really like to repaint the front end and fix the 2 dents in my Q pannel
-replace stupid sunroof that started to bubble
-M3 front brakes, I think imma need those
-Torn on what wheel to run next year, want wheels that can double as track wheels; also wanna throw some monies down on some good tires next year.
-Get the hooptie damn reliable enough so its track ready by spring(crosses fingers)
And if i can't resist the modbug to do anything to my 90' beater:
-GC's (softest rates possible) w/ Koni shocks
-I'm kinda itchy to own another 24v e30 but i'll try to keep my hands off this car
-A/C serivce (i think it kinda works now and it want it to work even better!!)
-Some epic ebay wheels, havent decided what yet.
