11-10-2009, 09:57 PM
E30 POWER
Car: e30 327I TURBO
Results of my stomp test
hey guys,,,,so i did the stomp test on my 88e30 convertible cause it has not been runnin proper and here r the results,,,,,,i need help figure out,,cause i dont under stanad the diagram givin when i google stomp test,,,,so this is what the check engine light did
it went blink,pause,blink,blink,pause,blink,pause,blink,pa use,then blinked and stayed on for like 4 sec and then started to repat itself,,,,if anybody nows what code that might be and can help me out that would be great
11-10-2009, 10:25 PM
Car: Worlds slowest E30
1211
1211 - DME, Motronic computer, related fault - which may indicate problem with car computer itself. Delete any stored codes and perform following test: Start the car and let it run for 30 seconds; Turn off car and let it sit for another 30 seconds; Perform diagnostic test again; If the same flash code re-appears DME should be replaced
91 318is - M50NV (gone)
85 - 325
11-11-2009, 01:49 AM
E30 POWER
Car: e30 327I TURBO
did that test and the problum is still there,,,,,so i guess i need to get one does anyone have one for sale
a few questions,,,,will any e30 dme work or will i need to particular on for my model,,,and also i have a stroker motor and it has a markd chip in it can i just swap this chip with out a problum,,
thanks
11-11-2009, 08:06 AM
Car: BMW
I should have the ecu - pm if interested
11-11-2009, 08:58 AM
You need a 173 ecu (out of a 325i).
Pretty readily available.
85 - 325
11-11-2009, 12:04 PM
E30 POWER
Car: e30 327I TURBO
parts
and wit the 173 its compatible wit the stroker markd chip i have i will be able t use that wit no problums
11-11-2009, 06:47 PM
Car: God's Chariot
You need to determine whether your car has a 153, or 173 DME. And no the chips are not interchangeable between the two.
11-11-2009, 07:16 PM
E30 POWER
Car: e30 327I TURBO
so this means thaat i am going to have to tottaly retune my car,,,i cant just take the one chip out of mine and put it into the new one
11-11-2009, 08:57 PM
Car: God's Chariot
Maybe not, again, it depends what computer is in your car. Then once you figure that out, find the same DME as a replacement, and the chip can be swapped over.
11-15-2009, 03:10 PM
#10
E30 POWER
Car: e30 327I TURBO
well bad news,,,,,i picked up another ecu this weekend and put it in and performed the stomp test again and it came up again that the dme was a problum,,,,,couls it be that there is a problum with something else wiring or something and its not the ecu,,,,,,this is driving me crazy ,,,,if anyone can give me a hand in what u think that would be great
thanks
