Old 11-06-2009, 06:24 PM   #1
old skoo
1st Gear Red Line
S54 m3 swap in an e30
Hey what's up people ? I'm planing on doin a s54 m3 swap in my e30 and I was wondering, what needs to be done in order to complete the swap ? Any1 have any ideas ?
old skoo is offline   Reply With Quote
Old 11-06-2009, 07:39 PM   #2
You need to buy said engine and install it into an e30. Sounds pretty simple.
Dat make cents 4 u guy?
Old 11-06-2009, 08:56 PM   #3
cormier
cormier's Avatar
just curious -- why were you thinkin S54 instead of S50/52?
Old 11-06-2009, 10:20 PM   #4
SamE30e
SamE30e's Avatar
Ohhh about 100hp...
And about 5 times the price. And 5 times the work.
85 325 - Turbo M52B28.
Old 11-06-2009, 11:12 PM   #5
msinger
might as well just copy the franken m3 build! wish i had that kind of money!!
http://www.cardomain.com/ride/2929437
msinger is offline   Reply With Quote
Old 11-07-2009, 01:08 AM   #6
e30_kid89
The Afro-stig
e30_kid89's Avatar
Pretty simple swapz. just drop in the engine into the desired vehicle and go!
Old 11-07-2009, 01:35 PM   #7
emdog16
its not that bad as long as you run standalone... nvm i take it back
emdog16 is offline   Reply With Quote
Old 11-07-2009, 01:39 PM   #8
Make sure you use the washer fluid that came standard on 03/2001 build Z8s. Once you got that down, the swap completes itself.
Old 11-07-2009, 01:49 PM   #9
davericher20
black and blue
davericher20's Avatar
don't forget that the upper cover for the vanos must be converted.
here this might help.
good luck.
Old 11-07-2009, 04:59 PM   #10
slimjim
Almost Sideways
just take it. and go
Old 11-07-2009, 07:51 PM   #11
SamE30e
SamE30e's Avatar
I heard you use a M10 Hotwire maf and it only bolts to the M20 sport auto tranny. Other then that it's wires up just like M50 swap.
Old 11-08-2009, 12:36 PM   #12
cormier
cormier's Avatar
my driveshaft suggestion -->
cut to size. duct tape flange.
