Old 11-04-2009, 10:07 PM   #1
Ihavenocar
Rear suspension E36
When ever i went over i go over a bump it goes kablang and shifted the car to the right i then got some m3 struts put em on but the right rear side is still noisy as if it hasn't been changed the strut shows no sign of leak or damage ?? any ideas?? Thanks in advance
Originally Posted by sirex View Post
why do u think Germans make cars... theyre not allowed to make tanks any more lol.
Ihavenocar is offline   Reply With Quote
Old 11-04-2009, 10:09 PM   #2
Skeezix
Did you check the rear trailing arm bushing?
Skeezix is offline   Reply With Quote
Old 11-04-2009, 10:10 PM   #3
Ihavenocar
no i have not ....will do thanks
Old 11-05-2009, 12:24 PM   #4
rdtx2005
agreed with Skeezix.. check the RTABs.. and your springs.
rdtx2005 is offline   Reply With Quote
Old 11-05-2009, 12:28 PM   #5
Sway bar link broken?
Old 11-05-2009, 12:38 PM   #6
RSM's?
Old 11-05-2009, 12:44 PM   #7
E30 Girl
E30 Girl's Avatar
Send a message via MSN to E30 Girl
^^^ I'm with Ivan I had a similar problem and it was my mounts.
E30 Girl is offline   Reply With Quote
Old 11-05-2009, 09:19 PM   #8
B-mZ
B-mZ's Avatar
trailing arm bushing fo sho, thats whats going on with my car to
B-mZ is offline   Reply With Quote
Old 11-06-2009, 11:02 AM   #9
Darkness95m3
Darkness95m3's Avatar
What they are saying is "Check everything".
Old 11-06-2009, 12:49 PM   #10
Waterwings
Waterwings's Avatar
RTAB had the exact same problem, and tried to fix the same way the first time too
"powered by passion and the equivalent of 900 horses"
Waterwings is offline   Reply With Quote
Old 11-19-2009, 09:16 PM   #11
Ihavenocar
ok i jacked the car up not the sway bar linkage that looked good saw that the rear trailing arm bushes are worn ...and my right rear tire was showing wear on the outer treads which were completly bald .... put on a new tire on it ...after inspecting the rear and seeing that only the rear trailing arm bushing was worn .. i have a question is this what is causing the loud banging and causing the rear end to dance ?
Old 11-19-2009, 09:36 PM   #12
Ihavenocar
and the uneven tire wear
Old 11-19-2009, 10:54 PM   #13
autodrjr
1995 325is totally stock.
autodrjr's Avatar
Send a message via MSN to autodrjr
it is odd that the outside is wearing as most bmws are cambered out at the rear alot stock... 2 inches i think. make sure the control arms are bolted in and the bushings there are tight... that can give you the noise and the jump around. otherwise the trailing arms from factory are not all that strong so make sure there straight
1995 325is M mouldings, 17 inch M5 wheels, clear lenses all around, fresh motor (mine)
1995 325i vert. Lowered, 18 inch M rep rims, intake, smoked lenses all around, hid's, angel eyes, intake, strut bar, m3 mouldings. plus tonnes more. (moms)
autodrjr is offline   Reply With Quote
