Old 11-06-2009, 11:53 AM   #16
Originally Posted by 325xi-guy View Post
Why wouldn't I? I have plenty of money and i live up north were you need all wheel drive and if i can end up pumping out over 300 hp out of my 325 it will be much more unique and satisfying than just buying a faster car.
You're not going to get over 300HP out of that motor without boost.
Old 11-06-2009, 12:05 PM   #17
richie_s999
I would just like to comment that HP numbers can be missleading when it comes to performance. Most power adding products use the HP number because it looks bigger, but that number usually comes at a high ass rpm level, after torgue has dropped off.
basically you could have a high HP motor, that doesn't match the performance of a lower HP motor.
Now b4 I get jumped yes HP is relative to torgue numbers, but you want both. I know Mark D designes his tunes with higer mid range torgue which provides drivable, usable higher HP numbers also. He adds power where it counts and doesn't chase the highest unusable number to be able to misslead strictly for people who see a high HP number and jump.
Also if the car is AWD....your goals to improve performance should be more related to torgue as your moving a heavier set of driveline components.
I also apload the OP for building the car he wants, and not giving into just buying the car everyone says is better....origional builds are more interesting and sometimes more complicated, but you end up with a wicked ride which is not cookie cutter.
Old 11-06-2009, 02:54 PM   #18
kkeddy
swap a m3 engine in there and call it a day if you wanna be unique someone did it on e46f. you can be the first in canada =)..actually no one did a xi yet i beleive...
2003 BMW 325i (sold)
2010 Civic Si (track) (sold)
2001 BMW e46 m3 (current)
kkeddy is offline   Reply With Quote
Old 11-06-2009, 03:11 PM   #19
Blades
Your opinion is to long
Blades's Avatar
and for good reason .. its cheaper to just buy an m3 and sell the current car .. or even cheaper then a swap on an xi .. get a supercharger.
-=[ BL/\DES ]=-
Old 11-06-2009, 04:37 PM   #20
tg07lq
i say XI swap an m3 lol, or do as was posted and m3 swap your XI,alternatively you could also look into a winter beater and pick up something else?
tg07lq is offline   Reply With Quote
Old 11-06-2009, 05:16 PM   #21
You could put a motor in the 325 (not hard to find a 330 motor).
Having said that, in your position (because swapping motors is harder cause of AWD), you really SHOULD be looking at boost.
Having said that, bolt ons aren't gonna do much for you, since what minimal gains you will get will be diminished by the greater torque loss and loss of responce cause of the AWD. Even a 330 motor will only give you a small bump in power. I've seen that type of AWD system hold up to 400hp on a daily driven car. Turbo kits for e46's are readily availble and not that expensive, most likely cheaper than an engine swap.
Think about it, do some research. I'm not one to jump into boost quickly either, but this is the right place to do it.
edit: you could also look at how the N54 AWD motor bolts up (on 335XI), might be possible to swap that in also.
Old 11-06-2009, 05:44 PM   #22
325xi-guy
You all have good points, and heres my views: first off I wont be doing an engine swap because of the awd like i said I live up north and it is nice to have stability through the snow, now having said that, yes I no you can get the 330 xi swap but there isn't a large enoph hp gain to make it worth the cash, I am going to use the cash to do a custum super or turbo kit in the spring. It has to be custum because no company makes a kit for an e46 325 xi but again having some custum performance under the hood will be a project and in the end I will be much more pleased with my finishing result.
Last thing, I no some of you are saying to simply buy a 330 xi and then upgrade but the main problem I have with that is that when i purchased my 325 it was between it and the 330 and in the end I found that driving the 325 was a bit more fun, I found that it was a nimbler car to drive and it had less understeer.
325xi-guy is offline   Reply With Quote
Old 11-07-2009, 12:19 AM   #23
Sickbimmer
750HP turbo E46 M3
Sickbimmer's Avatar
You'll have a problem custom tuning a turbo/supercharger on a E46. go with a supercharger. More kits and easier to tune then a turbo.(again, on a e46).
Sickbimmer is offline   Reply With Quote
Old 11-08-2009, 02:12 PM   #24
Blocked_Out
there are NO cheap HP upgrades
Blocked_Out is offline   Reply With Quote
Old 11-14-2009, 06:03 PM   #25
vladvm
waste of money.
just wait till you can afford a car you don't need to modify to stir your soul.
vladvm is offline   Reply With Quote
Old 11-14-2009, 10:47 PM   #26
Katmanz
Mwah!
Katmanz's Avatar
Is there such a thing??? A car that doesn't stir up the mod bug???
2001 330ci - Winter beater - RIP
2001 330i - Winter beater - RIP
2006 325i -
2012 x5 m sport -
Katmanz is offline   Reply With Quote
Old 11-15-2009, 01:57 PM   #27
cancan
Exclamation
Originally Posted by hamant View Post
Hvae you dyno'd it?
what numbers are you now pushing?
No, I didn't. And I don't have data prior to that. So, I have no idea.
cancan is offline   Reply With Quote
Old 12-08-2009, 12:38 AM   #28
fadi03325i
I have an 03 325i RWD which I bought stock for very cheap from a friend, all I've done so far is catback exhaust, CAI, suspension and better brakes,
Not really sure if its a good idea to do anything else since I'm considering selling it sometime in next 1-2 years for and getting a 330i,
03 325i
Stage One AFE CAI
Cross Drilled Brembo rotors and Akebono sport pads
UUC Catback Exhaust
20% Tints
H and R Touring Cup Kit
......hmmmmm - whats next?
fadi03325i is offline   Reply With Quote
Old 12-08-2009, 12:46 AM   #29
Another BM
Liar..
your 325 is not RWD...
Another BM is offline   Reply With Quote
Old 12-08-2009, 11:51 AM   #30
AdrianBmW
AdrianBmW's Avatar
Do a software upgrade.. check out Active Autowerke they have great products.
Black Sedan FTW
Active Autowerke Software/ Simota Carbon Fiber Cold Air Intake/ LED Angel eyes / 18in' Style M-166
AdrianBmW is offline   Reply With Quote
