Old 10-31-2009, 01:48 PM   #31
Well an LSD of any ratio is an upgrade from your open diff. But with the M50 manifold and tune, you'll be having a lot of fun with the shorter gearing.
Old 10-31-2009, 02:44 PM   #32
Fern3
formerly e36.M52B25
Fern3's Avatar
Very true, which bolts are we talking about exactly? The ones I should replace.
| M54B30/6MT Swap | KW V2 Coilovers |3.46 Diff |
|Genuine 19x8.5/9.5 Style 172M Wheels|
Fern3 is offline   Reply With Quote
Old 11-02-2009, 12:38 PM   #33
The main bolt on the front of the diff. If you pull up the diagram on realoem.com you'll see exactly which one it is.
Old 11-02-2009, 01:40 PM   #34
thinair
moderationistismingly
thinair's Avatar
I've gone through a couple diffs, I love my 3.38, I'd only go to something like a 3.46 or 3.73 if I had a 6spd transmission. Definitely replace the long diff bolt, and consider replacing the halfshaft torque bolts, or at least make sure they're properly torqued and locktighted.
You'd be surprised how much torque there actually is going through the rear axles, especially in the first couple gears, like over 2500ft-lbs of torque.
Old 11-02-2009, 03:17 PM   #35
ryanjv
ryanjv's Avatar
Send a message via MSN to ryanjv
so a 3.xx LSD from a 4.1 Open, is an upgrade?
ryanjv is offline   Reply With Quote
Old 11-02-2009, 04:27 PM   #36
Not at all with a 318. Everything I said was about the M52 motor.
Old 11-02-2009, 06:51 PM   #37
JunzieB
Wants more powaaa!
JunzieB's Avatar
Well, I just put a 3:23 in over my stock diff this wknd and i've been tricking myself the whole day thinking the car has added power.
I'm surprised no one has mentioned this as i found out for myself. The diff bolts right up but there maybe some adjustments required or parts brought over from your original diff.
If your car has a 4 bolt or six bolt driveshaft, you may need to get the LSD with the matching input flange. If not you'll have to swap the input flanges from the diffs.
Also, you may be required to swap the output flanges from the stock diff to the LSD as well to make the halfshafts bolt up.
Just advising as i never noticed this prior to doing the swap. Either that or i never paid attention to the more detailed DIY's.
Disclaimer:The opinions expressed by JunzieB is his alone and does not reflect the opinions of Maxbimmer or any members thereof. JunzieB is not responsible for any hurt feelings that may develop during the reading of his posts.
JunzieB is offline   Reply With Quote
Old 11-04-2009, 11:08 PM   #38
wrx_
are you talking about #16 on the below pic? thx
wrx_ is offline   Reply With Quote
Old 11-05-2009, 10:58 AM   #39
Yup.
16 Hex bolt with washer M12X1,5X80 ZNS3 1 33176760337
It's a special hardened bolt that you will be hard pressed to find anywhere but from BMW. It's 80mm long and takes a bunch of torque, don't skip this step!
Old 11-05-2009, 01:26 PM   #40
wrx_
Yup.
thanks alot
Old 11-05-2009, 02:36 PM   #41
JunzieB
Wants more powaaa!
JunzieB's Avatar
^^LMFAO @ the cream for knees campaign. How did i miss that thread?
Old 11-05-2009, 03:16 PM   #42
Fern3
formerly e36.M52B25
Fern3's Avatar
My install appt is tomorrow morning. Getting the gasket, fluid, bushings and bolts replaced. I will update te thread on what differences I feel after the install. Thanks for all of your advice guys.
Old 11-05-2009, 03:23 PM   #43
wrx_
what fluid are you going to use?
Old 11-05-2009, 03:58 PM   #44
Fern3
formerly e36.M52B25
Fern3's Avatar
redline 75w90
Old 11-06-2009, 10:31 AM   #45
wrx_
Originally Posted by e36.M52B25 View Post
redline 75w90
i'm going to install 3.91 LSD and was thinking of buying the same stuff.
where did u buy that? thanks
