Old 10-22-2009, 04:52 PM   #1
JINT
JINT's Avatar
Is there a PC cable for E30 OBD1 ?
I was wondring if it's common, or if anyone has the tool or the program and the cable to scan obd1 or if it's even needed. If yes, where could i get one. Thanks.
Old 10-22-2009, 05:48 PM   #2
SamE30e
SamE30e's Avatar
Mmmm nothing that cant be told through a stomp test.
85 325 - Turbo M52B28.
Old 10-22-2009, 08:33 PM   #3
richie_s999
Check craigslist. There is someone who sells odb1 to pc diagnostic set up on there
Old 10-22-2009, 10:19 PM   #4
JINT
JINT's Avatar
aright thanks richie
Old 10-23-2009, 03:42 AM   #5
Sam is right. Nothing will be revealed by a pc cable that you can't get with the car's on board diagnostics. Zero reason to buy a cable. Any cable I've ever seen is the Scanner 6.5 which does very little, if anything, on an e30.
Google E30 stomp test, trust me. Between that and a paper clip for the interval resets, you don't need anything at all.
Old 10-23-2009, 11:15 AM   #6
325isdan
This is good new about the pc cable. My car did not come with a Check engine light. Guess how happy I was when I found that out.
325isdan is offline   Reply With Quote
Old 10-23-2009, 11:10 PM   #7
JINT
JINT's Avatar
i don't have the engine light on or anything, but i just wanted to see why it's backfiring like crazy, advanced timing i guess
ps. and what the f@ck is a stomp test?
Old 10-24-2009, 01:59 PM   #8
325isdan
the stop test is when you stomp on the gas pedel ( 5 times maybe) and your check engine light will flash out any error codes that your car might have.
Old 10-24-2009, 03:41 PM   #9
If your CEL isn't lit, then neither a cable nor a stomp test will tell you anything. Why is your timing so advanced? I doubt that's your problem.
Old 10-24-2009, 03:45 PM   #10
JINT
JINT's Avatar
I don't know, i think it's running rich, gotta swap for some better injectors, i think my stock injectors are pissing already instead of spraying.
I tried the stomp test, no engine light, but something is bagning at the back, in the diff or the axle, i don't know, like metal against metal noise. Scares me abit.
Old 10-24-2009, 03:54 PM   #11
If your injectors weren't working well, you wouldn't be running rich. :p
Clunking in the rear is likely the rear subframe bushings, but you need to jack it up and give it a good look. Could also be trailing arm bushings, diff mount, center bearing support, rear shock mounts.
When does it make the noise?
You should probably make a new thread for this since it has nothing to do with a PC cable.
Old 11-04-2009, 11:09 AM   #12
J.Mcilmoyle
2nd Gear Grease Monkey
J.Mcilmoyle's Avatar
i saw on ebay that there was a obd1 to obd2 conversion im not sure how well it works tho
J.Mcilmoyle is offline   Reply With Quote
Old 11-04-2009, 12:37 PM   #13
That would be totally useless I'm afraid, if it even worked.
Old 11-07-2009, 03:26 PM   #14
magnus
magnus's Avatar
you aint getting a strong enough spark.
Its strong enough to make the ECU think it does but not strong enough to ignite. Change plugs and check leads and coil!
Thats your reason
http://pics.livejournal.com/blblblblx/pic/000r554e.gif
"Lo there do I see my father.
Lo there do I see my mother.
Lo there do I see my brothers and my sisters.
Lo there do I see the line of my people back to the beginning.
Lo they do call to me
they bid me take my place among them in the Halls of Valhalla,
where the brave may live forever"
magnus is offline   Reply With Quote
Old 11-07-2009, 09:03 PM   #15
JINT
JINT's Avatar
all that has been done, and no difference. I guess i gotta do rings
