Go Back   maXbimmer Forums > Platinum maXbimmer Sponsors > Bimmersport Automotive
Old 10-14-2009, 07:30 PM   #1
Jon@Bimmersport
Jon@Bimmersport's Avatar
Fall Inspection II special - limited space !
Hello board,
I noticed there has been a lot of calls for the inspection II service. I decided to make a package, for 10 people only! This is the same inspection II service, with all the same service/parts - the only difference is the price.
Call us to book your appt. and please provide your username at the time of booking. This service applies ONLY to E36/E46/E53 X5 6cyl vehicles and members of maxbimmer. Winter wheel swap is provided N/C considering it is the time of year. Due to the fact that there might be a demand for this, I can only entertain the first 10 people who are looking to book and follow through with their appt as this time of year we are extremely tight and cannot afford missed appts. Thank you.
Inspection II details:
Undercarriage
Change engine oil and filter oil while engine is at normal operation temperature.
Check transmission for leaks.
Check rear axle for leaks.
Visually check fuel tank, lines, and connections for leaks.
Check condition, position, and mounting of exhaust system. Examine for leaks.
Check power steering system for leaks.
Check overall thickness of front and rear disc brake pads.
Examine brake disc surfaces.
Clean brake pad contact points in calipers.
Grease wheel center hubs.
Check steering for absence of play, condition of suspension track rods, front axle joints, steering linkage, and joint disc.
Check front control arm bushing for wear.
Check brake and clutch system connectors and lines for leaks, damage, and incorrect positioning.
Check for free movement of the parking brake cables. Adjust parking brake if necessary.
Check all tire pressures (including spare). Correct if necessary.
Check condition of tires (outer surfaces (left/right)), tread wear and pattern; In case of uneven tread wear readjust wheel alignment if required.
Check thickness of parking brake linings.
Half-shafts; check for leaks at flexible boots.
Inspect entire body according to terms of rust prevention limited warranty.
Remove/clean/lubricate brake pads/sliders
Engine Compartment
Read out diagnostic system
Replace fuel filter
Check engine cooling system/heater hose connections for leaks.
Check coolant level and antifreeze protection level; add coolant if necessary.
Check level of brake and clutch fluid in reservoir; add fluid if required.
Check windshield washer fluid level and antifreeze protection. Fill up and/or correct if necessary.
Check air conditioner for operation.
Reset Service Indicator.
Replace spark plugs.
Replace intake air cleaner element.
Body/Electrical Equipment
Check battery electrolyte level and add distilled water if required.
Perform batter load test.
Check lighting system, i.e. headlights, foglights, parking, backup, license plate, interior (including map reading lights), glove box, flashlight, illuminated makeup mirrors, luggage compartment lights.
Check instrument panel and dashboard illumination.
Check all warning/indicator lights, check control.
Check turn signals, hazard warning flashers, brake lights, horns, headlight dimmer/flasher switch.
Check wiper and washer system(s); wiper blades, washer jet positions.
Check condition and function of safety belts.
Oil hood, trunk/tailgate, and door hinges.
Grease hood, trunk/tailgate and door latches. Check operation of all latches.
Check central locking/double lock.
Check heater/air conditioner blower, rear window defogger.
Check rear view mirrors
Visually examine the SRS airbag units for torn cover, obvious damage or attachment of decals, decorations, or accessories.
Replace cabin microfilter - (e36 .5H additional)
Final Inspection
Road test with check of brakes, suspension, steering, clutch/manual transmission or automatic transmission
Old 10-15-2009, 01:30 PM   #2
King Luis
The King.
King Luis's Avatar
does this include valve adjustment and M cars?
i might be in for monday morning.
Mods: TBD.
Sold:2004 Silver Gray M3
Gone:1990 Brilliantrot 325is
Old 10-15-2009, 01:59 PM   #3
Jon@Bimmersport
M cars arent included in this price.
Sorry guys! Hey, if you M guys want get me at least 5 and Ill make something up for you.
Old 10-15-2009, 06:33 PM   #4
BabyHerc
So how much is this discounted price?
BabyHerc is offline   Reply With Quote
Old 10-15-2009, 08:37 PM   #5
Jon@Bimmersport
The special price is $450 plus tax
Old 10-26-2009, 11:25 PM   #6
lightsandsirens
lightsandsirens's Avatar
I'll call to make an appointment if there is still a spot for the group special.
I can even drop and leave the car there for most of the day.
Gabe
Good bye Japan, hello Bavaria
lightsandsirens is offline   Reply With Quote
Old 10-27-2009, 02:38 PM   #7
Jon@Bimmersport
There is one more spot, if you would like to take it please call me.
Old 10-29-2009, 01:55 PM   #8
EMPIREM3
Catch me if you can.
Send a message via MSN to EMPIREM3
Jon, can you post up a price for Ms ? im sure we can find 5 Ms for this.
///M Power
EMPIREM3 is offline   Reply With Quote
Old 10-29-2009, 03:44 PM   #9
M3GA
formerly Custom330
I'm down with the M3 cars, however, I need Insp1 done before I store the M for Winter... so if Bimmersport can arrange a good deal with 5 M cars for Insp1/2 then I'm in.
M3GA is offline   Reply With Quote
Old 10-29-2009, 07:09 PM   #10
Jon@Bimmersport
So we have 2 out of 5
If there is 5 people, I will do it.
We will do it $575 - does not incl valve adjustment. This is special price for Inspeciton II.
Old 10-30-2009, 11:56 AM   #11
duhprez
Inspection II for M3
Hey Jon,
Sent you a PM for inspection II for my M3 vert. Maybe I'll be #3
Thanks,
Ben
2003 BMW M3 Vert
duhprez is offline   Reply With Quote
Old 11-03-2009, 11:58 PM   #12
CanadianE46M
Hey! Just so everyone knows, I've already tagged in with Jon as #4 for the M3's, as long as the other three are in.. we need one more!! Any takers out there?
CanadianE46M is offline   Reply With Quote
Old 11-04-2009, 01:33 AM   #13
CoEEzi
how much extra is the valve adjustment... I maybe down for the M
CoEEzi is offline   Reply With Quote
Old 11-04-2009, 12:35 PM   #14
Jon@Bimmersport
PMs replied !
Old 11-04-2009, 05:41 PM   #15
CoEEzi
ill be #5.....are all the M's down for this?
Copyright ©2000 - 2016, Jelsoft Enterprises Ltd.
