Old 10-17-2009, 07:48 PM   #1
325isRED
325isRED's Avatar
Question bizarre Tire Wear!!?
Hey all,
Today I decided to put on the winter tires, a bit early I agree, but my schedule doesn't get any lighter until the term ends. Anyway:
My rear tires are showing some very unusual wear. The inside corner is worn at a very sharp angle. My car is lowered, however, the camber which my rear wheels have definitely is not nearly sharp like this. Here are some pics, more story below the pics.
Notice the sharp wear on the left side (inside).
Here I've approximated the wear.
The other tire.
Something to think about. I am currently experiencing some differential issues ( http://maxbimmer.com/forums/showthread.php?t=124578 ) which I think leads to improper "slip" around corners. Could this wear be a example of that?
Any ideas?
'92 325is 5sp
Old 10-17-2009, 09:06 PM   #2
Eurostyle
Eurostyle's Avatar
I would say thats pretty normal for a lowered bimmer! The wear could also be coming from bad alignment...with much toe in would cause your wheels to look like this (when you look from top of the car); /----\ so the inside of the tire will wear out more, even tho the camber is good.
Old 10-17-2009, 11:47 PM   #3
Gamite
Gamite's Avatar
alignment
www.gamite.net
Old 10-18-2009, 03:07 AM   #4
ClayMan
definite toe wear.. get an alignment.
ClayMan is offline   Reply With Quote
Old 10-18-2009, 03:41 AM   #5
Swerve
///Maquina
Swerve's Avatar
what if your front tires look like this?
don't mean to hijack this thread, but seems like the cause of 325is' rear wear has been identified.
Old 10-18-2009, 08:41 AM   #6
sparkybp
Tortures BMWs.
sparkybp's Avatar
Same issue with the front, usually a combination of negative camber and excessive toe in or out, mostly caused by the excesive toe in either direction. When there is a toe issue camber will become an issue too but camber alone could not cause that kind of wear.
Old 10-18-2009, 10:51 AM   #7
philthy328
Send a message via MSN to philthy328
Exact same thing happened to me. To much toe on the front, alignment solves it.
philthy328 is offline   Reply With Quote
Old 10-18-2009, 11:38 AM   #8
325isRED
325isRED's Avatar
Thanks for the input guys! My next question now is where to get a proper alignment in the west end?
'92 325is 5sp
