Old 10-13-2009, 12:03 PM   #1
Gamite
Gamite's Avatar
Manhart Racing V10 E91 M3 Touring
Attention all sporty, family men! The new BMW M3 is also available as a four-door saloon. That means it's very easy to justify buying a new plaything to your sceptical wife (or, in fact, to your own conscience). It's just a shame that the Bavarian company hasn't yet been able to bring itself to make an M3 estate.
The tuners at Geilenkirchen-based Manhart Racing probably thought the same thing when they built the car that BMW didn't want to build; an M3 touring. To produce it, the team centred around legendary mechanic Günther Manhart, furnished the E91 bodywork with the front apron, front side panels, side skirts and of course, the characteristic powerdome bonnet from the M3 saloon, designed their own M3-style rear apron and widened the rear wheel-arches to give them that M3 look. The aerodynamic rear-view mirrors really topped it all off. However, Günther Manhart knows that you obviously can't just make a car look good; it has to have something under the bonnet too. The axles, the tank, the complete steering system and a range of other hidden but otherwise essential parts have all come from the M3.
V10 power in the E91
So it only remains to talk about what really makes the M3: The 4.2-litre V8 engine. But wait! At this point it should be mentioned that Manhart Racing specialises in fitting various BMW models with the formidable 5.0-litre engine from the M5 E60. And so the V10 engine found itself used in another BMW model, the E91. After optimising the electronics and incorporating HJS's stainless-steel four-pipe exhaust system with two 200-cell racing catalytic convertors, the heavy-duty unit manages an extremely impressive 550 PS, which is kept on a tight leash by the 7-speed SMG gearbox, also taken from the M5 and by the corresponding 100% limited slip differential
With the vehicle possessing such an armoury, it can catapult itself from 0 to 100km/h in only 4.3 seconds and on the motorway it easily cruises past most other performance saloons and estates (including the ‘true' M3 and M5 models) with its top speed of 324km/h.
It's a good thing then, that Manhart Racing has equipped the car with tunable Bilstein PSS10 coilover suspension and an extremely stable Stoptech Sport Trophy Kit braking system with a six-piston calliper with grooved 380mm brake discs at the front and a four-piston calliper with 355mm brake discs on the drive shaft.
The RÄD Monza three-part forged wheels with black rims fit perfectly with the character of this vehicle, and they are available in 9.5" and 10.5" x 20" sizes.
Flat, size 255/30ZR20 and 295/25ZR20 Hankook S1 Evo tyres aim to provide higher levels of longitudinal and lateral acceleration.
Performance interior
A detailed look at the interior is also very much worth your. Driver and passenger both sit in outstanding BMW sports seats, and the back seats can be upholstered with leather or Alcantara to match those in the front. Likewise, the leather interior with Alcantara roof and door linings as well as the carbon fittings and the BMW performance steering wheel with illuminating indicator switches really give the car that racing look.
Manhart Racing has set the purchase price for the complete car package at around €120,000. If desired, your current basis car can be upgraded.
Technical facts
Vehicle: BMW M3 E91 5.0 V10 SMG
Bodywork: M3 E90 front apron, M3 E90 front fenders, M3 E90 bonnet, M3 E90 side skirts, M3 E90 wing mirrors, Manhart Racing-designed, M3-style, rear apron, widened rear wheel arches in the style of the M3.
Engine: 5.0-litre V10 from the M5 E60, modified engine electronics, lifting of the Vmax limiter, complete stainless steel exhaust system with 2 x 200-cell HJS catalytic converters and 4 x 86mm exhaust pipes, tank from the M3 E90, 550 PS.
Transmission: 7-speed SMG from the M5 E60, 100% limited slip differential from the M5 E60, front and rear axel from the M3 E90.
Chassis: Bilstein PSS10 coilover suspension, steering system from the M3 E90.
Brakes: Stoptech Sport Trophy Kit front and back, 6-piston callipers and 380mm slats in the front, and 4-piston callipers and 355mm slats at the rear.
Wheel/Tyres: three-part RÄD Monza aluminium rims in 9.5" x 20" ET20 and 10.5" x 20" ET20, Hankook Ventus S1 Evo Tyres in sizes 255/30ZR20 and 295/25ZR20
Interior: heated BMW performance sports seats, leather-covered back seats in the style of the front seats, full leather interior with Alcantara roof and door lining, BMW performance steering wheel with illuminating indicator switches, acceleration and ¼ mile time displays.
Source: http://www.worldcarfans.com/10910132...manhart-racing
www.gamite.net
Old 10-13-2009, 01:08 PM   #2
Blades
Your opinion is to long
Blades's Avatar
omg .. do want
-=[ BL/\DES ]=-
Old 10-13-2009, 01:43 PM   #3
arsevader
'85 325e
'90 325i
'02 325it
'03 320i
'96 Volvo 850R
arsevader is offline   Reply With Quote
Old 10-13-2009, 02:46 PM   #4
DANIMAL
TYRE ETR
DANIMAL's Avatar
Sweet Jesus! That thing is sick.
DANIMAL is offline   Reply With Quote
Old 10-13-2009, 04:32 PM   #5
AMG_POWER
500HP Member
I wonder how much would it cost to buy and put v10 into e90/92.
Anyone have an idea?
AMG_POWER is offline   Reply With Quote
Old 10-14-2009, 01:14 PM   #6
Fern3
formerly e36.M52B25
Fern3's Avatar
http://cgi.ebay.ca/ws/eBayISAPI.dll?...T#ht_829wt_939
Well a used M V10 will run you $15,000 if the customs officer is feeling generous, and labour for dropping it and fabricating all the custom brackets and mounts you'll need will probably run you another 5,000 at a decent shop. so about 20 grand sounds right?
| M54B30/6MT Swap | KW V2 Coilovers |3.46 Diff |
|Genuine 19x8.5/9.5 Style 172M Wheels|
Fern3 is offline   Reply With Quote
Old 10-24-2009, 05:23 PM   #7
Majjic
Majjic's Avatar
looks awesome !!!
- 88' E30 M3 -
Majjic is offline   Reply With Quote
Old 11-06-2009, 09:39 PM   #8
magnus
magnus's Avatar
Sweetest family car ever!!!
Hope it aint a repost!
Wedging BMW's V10 into an M3 is nothing new, but what if you want the convenience of a wagon? Manhart Racing has the answer. The German tuner has converted an E91 to look like the M3, then stuffed M5's V10 into the engine bay complete with its seven-speed SMG. To quote Manhart Racing..."Attention all sporty, family men!"
The transformation from a standard E91 3-Series Estate to super wagon begins with the exterior, where the car gets the front fascia, front fenders, side skirts, and the powerdome hood from the M3. Manhart Racing then adds their own rear wheel arches and rear fascia that makes room for a stainless steel exhaust system sporting quad exhaust tips. Next, the 5.0-liter V10 gets stuffed into the engine bay along with the the gearbox, and a limited slip differential is mounted out back.
Manhart claims a 0-100 km/h time of 4.3 seconds and a top speed of just over 200 mph. You can buy your own turnkey version for a mere €120,000 or Manhart will gladly upgrade your current E91. Hit the jump for full details.
http://www.autoblog.com/2009/10/13/g...-bmw-m3-wagon/
http://pics.livejournal.com/blblblblx/pic/000r554e.gif
"Lo there do I see my father.
Lo there do I see my mother.
Lo there do I see my brothers and my sisters.
Lo there do I see the line of my people back to the beginning.
Lo they do call to me
they bid me take my place among them in the Halls of Valhalla,
where the brave may live forever"
magnus is offline   Reply With Quote
Old 11-06-2009, 10:22 PM   #9
SamE30e
SamE30e's Avatar
Fuuuuuuuuuccckkk me!
85 325 - Turbo M52B28.
Old 11-06-2009, 10:54 PM   #10
Quack
Wheelman
Quack's Avatar
sick!!!!
Old 11-06-2009, 11:30 PM   #11
Razkal
Razkal's Avatar
I would take that in a heartbeat
Rides:
08 SG/FR BMW M3 E90 sedan
11 White BMW X3
Need any assistance branding your company/services? :
http://www.bluemouse.ca
__________________________
Razkal is offline   Reply With Quote
Old 11-07-2009, 11:45 AM   #12
Daddy
wow! i want one!
Daddy is offline   Reply With Quote
Old 11-07-2009, 12:31 PM   #13
koncise
all you need is one mike
koncise's Avatar
Send a message via MSN to koncise
ditto
koncise is offline   Reply With Quote
Old 11-07-2009, 01:36 PM   #14
davericher20
black and blue
davericher20's Avatar
it's a justified family car
Old 11-07-2009, 02:25 PM   #15
Fel
Not Banned
Fel's Avatar
That's pretty sweet... I'd drive that.
