Old 10-08-2009, 03:27 PM   #1
J.Mcilmoyle
2nd Gear Grease Monkey
J.Mcilmoyle's Avatar
power winder and sunroof quit working
hey guys i have a 87 325e 2 door and when i got the car the power windows never work and the sun roof just quit working stuck open if any one has any ideas oh how to fix or even close the sun roof thanks for any that can help
jeff
J.Mcilmoyle is offline   Reply With Quote
Old 10-08-2009, 04:28 PM   #2
dmytro
dmytro's Avatar
Did you checked fuse box?
dmytro is offline   Reply With Quote
Old 10-08-2009, 05:45 PM   #3
e30jones
Does the motor try and work, but can't; or is it totally dead. Power sunroof can be closed manually with an allen key by popping off the cover (rectangular) and cranking it shut manually. That is, unless the reason it stopped working is becuase the cables broke, or the cables are out of synch, causing it to bind. Then you're SOL. You'll have to take the panel off to fix.
e30jones is offline   Reply With Quote
Old 10-08-2009, 10:08 PM   #4
Ceeker
Always check the obvious first. Go to the weakest link- as said above - fuses.
Then work your way from there - motor's sometimes go weak and pack in .. this was and is a common problem with e30's. also check the microswitch for the motor. they get wonky too.
1 90 325is white - keepin
1 87 325i vert -red - keepin
KEEPER 88 5sp Vert 2016
Old 10-09-2009, 10:47 AM   #5
J.Mcilmoyle
thanks guy i got the sunroof closed. but the windows dont even try to close. but i think iv check everything for the door windows but i cant get power to the switch. thanks for the help
jeff
Old 10-09-2009, 11:38 AM   #6
Make sure you have the interior breaker switch clicked in for the windows. That would kill power to them.
Old 10-09-2009, 12:30 PM   #7
J.Mcilmoyle
and thats the switch up on the dash next to the four ways right
Old 10-09-2009, 12:56 PM   #8
Yes
Old 10-09-2009, 04:50 PM   #9
J.Mcilmoyle
ya i played with that and still nothing
Old 01-08-2010, 12:43 PM   #10
Denny
have you been able to resolve this? I got the same problem.
Anybody have a diagram of the fuse box which fuses are what..sorry for my newb question just got the car few days ago.
Denny
___________
2003 BMW 330i M-sport AA SC 5-speed -SOLD
2006 BMW 330i 6-speed black SOLD
2001 BMW X5 4.4 - Auto - black on black - SOLD
1989 BMW 535i - 5-speed - black -SOLD (kept M30B35/tranny for E30)
1985 BMW 325 E 5-speed (new project)
1987 BMW 325 5-speed - work in progress
http://bmw325e30.blogspot.com/
Part 2 (Supercharger/turbo build)
http://bmw325e30turbo.blogspot.com
Other interests:
http://www.xbox360.com
http://bodyspace.bodybuilding.com/dennymedeiros
Denny is offline   Reply With Quote
Old 01-08-2010, 03:43 PM   #11
Ceeker
look in your owners manual. it will be in there. first check fuses, if good then check your switches. Also check the breaker switch to make sure it didn't close the circuit upon it malfunctioning. if it still no luck then test for continuity from switch to window motors.
You can also try banging the door panels. sometimes the motor connection shorts.
Old 01-08-2010, 03:53 PM   #12
nonlocal
Last of the Late-Brakers
nonlocal's Avatar
Maybe you, like me, don't have an owners manual... this might be helpful:
http://forums.pelicanparts.com/101-p...-fuse-box.html
Google returns a bunch of stuff on my search for "e30 fuse diagram." But you already tried that, right?
Old 01-08-2010, 03:56 PM   #13
nonlocal
nonlocal's Avatar
Might as well just have it in this thread:
BMW E30
Fuses
# Rating Description
1 7.5 A Headlight, left high beam
2 7.5 A Headlight, right high beam
3 15 A Aux. cooling fan, low speed
4 15 A Turn signals
Emergency flasher
Active Check control
Digital Clock
5 30 A Windshield wiper and washer
6 7.5 A Stop lights
Cruise control
Active check control
ABS
Interior lights
7 15 A Horn
8 30 A Rear defogger
9 15 A Fuel delivery
Idle speed control
10 7.5 A Seat belt warning system
Service interval indicator
Tachometer / fuel economy gauge
Instrument gauges and indicators
Brake warning system
Back-up lights
OBC
Starter
Fuel delivery
Idle speed
Stop lights and cruise control
11 7.5 A Fuel pump
12 7.5 A Radio power
Speedometer / instrument indicators
OBC
Multifunction Clock
13 7.5 A Left Low Beam
14 7.5 A Right Low Beam
15 (Not used) jg
16 15 A Heated Seats
17 30 A Power sunroof
Power windows
18 30 A Aux. cooling fan, high speed
19 7.5 A Aux. cooling fan
Interior lights
Power mirrors
20 30 A Heater / Air conditioner
Auxiliary Radiator cooling fan
21 7.5 A Glovebox light
Flashlight
Ignition Key / Seat Belt warning
Interior Lights
Radio Memory
Trunk Light
Active Check Control
Service Interval Indicator
OBC
Fuel delivery Tachometer / Fuel Economy Gauge
Digital Clock
Multi Function Clock
22 7.5 A Active Check Control
Front Parking Lights
Taillights
Front Side Marker Lights
23 7.5 A Instrument Panel Lights
Taillights
Rear Side Marker / License Plate Lights
Rear Defogger
Multi-Function Clock
OBC
24 15 A Turn Signals
Emergency Flasher
25 (Not used)
26 (Not used)
27 30 A Interior Lights
Central Locking
OBC
Radio Amplifier
28 30 A Lighter
Power Antenna
29 7.5 A Left fog light
30 7.5 A Right fog light
Old 01-09-2010, 01:29 AM   #14
richie_s999
where is the fuze box though???
Old 01-09-2010, 02:28 AM   #15
nonlocal
nonlocal's Avatar
Should be right under the cap marked 'ATF Only'...
