Old 10-06-2009, 03:31 PM   #1
rdtx2005
can a 325i diff be put in a 328i with no modifications?
thanks in advance
automatic btw
rdtx2005 is offline   Reply With Quote
Old 10-06-2009, 04:27 PM   #2
ScotcH
Yes. You might run into an issue with the input flange being different (6 bolt vs 4 bolt), but that can be swapped.
Old 10-06-2009, 04:46 PM   #3
craigIS
A.K.A. crossfire291
craigIS's Avatar
as far as i know it should work, but as stated before by ScotcH, the flange may have to be swapped.
flickr
Old 10-06-2009, 10:18 PM   #4
All the 328 autos I have seen are 4 bolt, like the 325 BUT you have to swap output flanges (larger axles)
Old 10-06-2009, 10:29 PM   #5
ScotcH
All output flanges are the same, Fil. Only the M3 is larger.
Old 10-06-2009, 11:44 PM   #6
318/320 are smaller then 325/328! I forgot the 325/328 are the same since most people switch from 318 to 325/328 and have to upgrade flanges/axles!...
318/320=80mm
325/328=86mm
M3=94mm
Old 10-07-2009, 12:38 AM   #7
ScotcH
318/320=80mm
325/328=86mm
M3=94mm
Good info ... sorry, I forget there are cars below the 325
