Welcome to!
Old 10-05-2009, 03:05 PM   #1
How to prevent/reduce coilover corrosion?
Is there something I can do like spray the coilovers with some liquid to prevent corrosion before the nasty stuff comes? These are KW brand coilovers...
Daddy is offline   Reply With Quote
Old 10-05-2009, 03:35 PM   #2
E36is's Avatar
if you can find it, there is a product called 'Liquid Plastic', apply it over the entire coil thread and spanner nut once the desired height is attained, then just liberally brush on the product. 3 or 4 coats will provide you with the protection. In spring/summer just use an exacto knife and peel off the plastic. Also spray on some PAM before covering, this will make the peeling off much easier. This is just one method.
Old 10-05-2009, 06:27 PM   #3
Buy KW inox line coilovers and don't worry about corrosion ever.
Old 10-06-2009, 08:52 PM   #4
braindamage's Avatar
Canadian Tire sells it. It works for me...
braindamage is offline   Reply With Quote
